SOURCE: My Sony WEGA KP-FX432M91 TV LED blinking few times
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
SOURCE: My sony Wega KP-57WS520 TV blinks 9 times and the
Replace D6301 and D6116 on G board, and also IC8002 on D board.
SOURCE: My Sony Wega rear projection TV has green
I hate to tell you this but if your light enginge /optical block is bad you are Looking at just for Part $1,949.95 core refund is $1,300.00 Then part is 649.95 Encompass Parts Distrubtion has 23 of them
1-800-638-3328 Chances are it is your Light Engine!
SOURCE: MY SONY PROJECTION TV WEGA KP-FX432 BLINKS 10
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
SOURCE: The image on my sony kp-51hw40 tv looks 3d. Image
This set uses two of the STK-392-570 IC chips for this (convergence problem) on EBAY about 14 dollars for a pair.
It can be a do it yourself repair depending on your skills.
Getting at them, and being able to solder and remove/replace them is the repair.
Let me know how handy you are, I can provide photos of what they look like and what the board inside the set they are on looks like.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
