Televison & Video Logo
Ron Heath Posted on Mar 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there any polarity on a2 wire 2uF 450v fan running capacitor
Jay Plesset
Level 3:
  • Televison & ... Master 2,942 Answers
  • Posted on Mar 15, 2019
Jay Plesset
Level 3:
Answers
2942
Questions
Helped
667816
Points
9879
No polarity. It's AC, not DC. The capacitor is a "non-polar" type.
2 Related Answers
Anonymous
  • Posted on Oct 24, 2010
SOURCE: i have a floor fan
no, the capacity is way too high.... get a capacitor of at least 1,5 uF or up to max 4 uF if you happen to have one lying around
richie46
  • 12962 Answers
  • Posted on Aug 06, 2015
SOURCE: will a 16uf 450v generator capacitor work in place of a 12uf 450v generator capacitor
Yes it will. The key is to not go lower in capacitance or in rated voltage. As you go up in cap size the cost will also go up so you want to stay pretty close to rated value unless dinero is no object.
Testimonial: "Thanks for the info I just happen to have a 16 uf"
1helpful
My Fisher and Paykel dryer (#ED56) won't start. Turns on, low hum
The Start/Run Capacitor has failed. The capacitor give the motor a voltage jolt to get it going.
Capacitor - 7uF
Fisher & Paykel https://www.fisherpaykel.com > laundry-spare-parts
Capacitor 7uF for Dryer. 400V. Note: Does not suit some older models with an Emmerson (square) motor. Capacitor - 7uF. $ 43.83. Add to Cart. $ 43.83Each.
A$43.83
Capacitor 7uF 450V Fisher Paykel Dryer ED57, AD55AU ...
eBay https://www.ebay.ca > itm > Capacitor-7uF-450V-Fish...
Capacitor 7uF 450V Fisher Paykel Dryer ED57, AD55AU 93214A, ED56AUFP, AD55AU ; Type. Capacitor ; Installation. Built-In/Integrated ; Compatible Model. ED57, AD55AU ...
A$12.95
Fisher & Paykel Dryer Capacitor for Motor 7UF Microfarad
Steve's Appliance Spares https://www.appliancespares.nz > products > fisher-pa...
Genuine ICAR Capacitor Genuine Manufacturer used by Fisher Paykel for dryers, ActiveSmart fridge-freezers and sold by spa pool stores across NZ DUCATI.
NZ$13.03 ..
2helpful
2answers
Can I use a 2uF capacitor instead of a 1.8uF in a ceiling fan also would it affect performance
Should work fine. This is only 10% difference and manufacturing tolerance is typically 20% for this kind of component.
Mar 15, 2019 • Dryers
2answers
My fisher paykel ed56 dryer powers on, I can press the start button but nothing happens, it just makes a humming noise. There are no error lights flashing.
The Start/Run Capacitor has failed. The capacitor give the motor a voltage jolt to get it going. A 'humming noise is a giveaway for that issue.
Capacitor - 7uF
Fisher & Paykelhttps://www.fisherpaykel.com > laundry-spare-parts
A$43.83
eBayhttps://www.ebay.ca > itm > Capacitor-7uF-450V-Fish...
A$12.95
Steve's Appliance Spareshttps://www.appliancespares.nz > products > fisher-pa...
NZ$13.03
Acquired snap on ya219 that didn't weld. Replaced the capacitor. Powered on and struck an arc on the the ground lead. I removed the welding wire and noticed that when the wire speed was turned all the way...
Could be a shorted output rectifier (diode). This would cause a lot of current pull, and therefore voltage drop (fan slowing down). The electrolytic capacitors are for dc voltage, and will blow with wrong polarity, which means ac voltage would be the wrong polarity half the time.
When you plug it in asoon as the thermostat kicks on the motor hums then starts and runs bacward. If you spin the fan the correct direction when it is humming it will sart and burn properly. I do live in...
Look for a capacitor. Have it tested, it may be a start capacitor for the motor, which would get it going the right way. Don't worry about polarity on the cap, but you can mark the connections if it looks important.
HOMS Evaporative Air Cooler HW:777 Slow / Not Rotating Motor, What Could Be The Problem?
capacitor for run motor has gone most likely. on the motor you will find a black box with ether 2 black wires or one black and other white with something like cbb61 ac450. that has probably gone. they in most 2 phase motors and 3 phase motors like ceiling fans. dont cost a lot to replace just make sure it is the right uf rating can be 1 uf up but not down. so say yours is 1uf and you fing a 2uf it would be fine but a 4uf will make the motor slower.
5helpful
2answers
I have a floor fan with a bad capacitor. its a 1.5uF +-5% 450V. can i replace capacitor with a 33 uF 250 ~ 275 V capacitor ? or with some other one that i got ?
2answers
Hampton Bay Garrison 52" fan stuck on high
nothing wrong with the power supply, or the remote, the speed switch in the fan is faulty, as it is more finiky than a manual speed change(like with a cable)
Lpine Type-X 5.25 component speakers- Crossover problem
You can use any providing you can determine the max voltage in the device and the polarity.
If the capacitor in the unit has a wire out of each end and both ends have indents then it's a non-polar type.
Speaker capacitors for tweeters tend to be around 2uf.
The Voltage of the capacitor should be bigger than any voltage in the device.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
