Cameras Logo
Enzo Turco Posted on Mar 15, 2019
I have an Oricom Ultra 550 that won't recharge. The green light on the charger is on but doesn't go red when unit is placed in it .
Jyothilekshmi B
Level 1:
Habit-Forming:
Scholar:
  • Contributor 35 Answers
  • Posted on Mar 19, 2023
Jyothilekshmi B
Contributor
Level 1:
Habit-Forming:
Scholar:
Answers
35
Questions
Helped
3914
Points
65
It sounds like there may be an issue with the charging system on your Oricom Ultra 550. Here are a few troubleshooting steps you can try to resolve the issue: Check the power source: Make sure that the power outlet you are using is working correctly. Try plugging in another device to confirm that the outlet is providing power. Check the charger: If possible, try using a different charger to see if the issue is with the charger itself. If you don't have another charger, try using a different USB cable with the charger. Check the battery: If the battery is completely drained, it may take a few minutes for the charging indicator light to turn red. Try leaving the Oricom Ultra 550 in the charger for 10-15 minutes to see if the light changes to red. Reset the device: If none of the above steps work, try resetting the device. To do this, remove the battery and then put it back in. Turn the device on and see if it starts charging. If none of these steps work, it may be a hardware issue with the device. In that case, you may need to contact Oricom customer support for assistance or take the device to a technician for repair.
5 Related Answers
Anonymous
  • Posted on Nov 18, 2008
SOURCE: Cobra PR3850WX will not recharge batteries
There is a contact in the upper left hand corner of the batt compartment.This has to touch the metal of the last batt.If your batts have paper around them scrape it off where it contacts that contact point.
Anonymous
  • 7 Answers
  • Posted on Jun 08, 2009
SOURCE: rechargeable batteries are blinking red when
put one battery at a time ,when it turns red that battery is bad.
Anonymous
  • 193 Answers
  • Posted on Nov 29, 2009
SOURCE: Flashing charging lights when on charger.
smething internal is burnt out possible bad battery.
Anonymous
  • 1961 Answers
  • Posted on Apr 19, 2011
SOURCE: Almost new..three recharges...was working fine,
After charging use a voltage tester to measure the voltage from the battery the reading must be equal to what is the voltage output of the battery 12v or 24 volts if you can measure the correct out put voltage then the battery is full charge the scooter should work well.
If you measure a low voltage means you need to full charge first the battery before operating.
to measure the battery voltage put your red test prove to the positive terminal of the battery (red)and black test prove to the black terminal of the battery....If the battery is full charge and the scooter wont run there is a problem on the motor cleaning the carbon brush of the motor will solve the problem... good luck!if you need further assistance just post back!
emissionwiz
Marvin
  • 85242 Answers
  • Posted on May 18, 2011
SOURCE: Cannot recharge 18v battery, place
You will need to replace the battery it is defective.
1helpful
What kind of batteries for the evatac flash light
My Evatac flashlight rechargeable batteries not working .when connecting batteries to charger light flashes green red green red ect. What is the problem
Jan 27, 2019 • Cameras
2answers
Wiring for 6 pin oricom mic plug
I too have an Oricom 6 pin mic with wires broken pin 1 is white, 2 is black and 5 is screen, this does not match any of the above answers and the green blue & red are off with 2, 3, 4, & 6 available
Kevin H
The light on the end of the dock stays red. Battery when recharged turns green. When placed back on the dock, then the light goes back to red.
Turn your camera on and look at the battery life after you had it charging for a while. your rechargable batteries may be bad or getting bad. Try trading out the rechargeable batteries or try plugging in your charger on a different outlet at home
Mar 04, 2011 • Cameras
3helpful
What does it mean when a household battery charger flashes red then green? The charger is a SYNERGY DIGITAL rapid quick charger. I'm trying to charge new AA Energizer Lithium batteries.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
1helpful
I have an Energizer E2 Slider battery charger, Is the green light supposed to stay on when charging. Does it shut off when charge complete.
all chargers show a light of some colour when charging , green or red , depending on make of charger , when the battery is fully charged the unit monitor this and automatically switch of to stop from over charging , a safety feature that has to built in for safety reasons ,
Rechargable Batteries Battery Charger
When batteries are placed into the charge mode, the red light will come on.
When fully charged, on those units with a green light, the green light will be an indication that your batteries are charged and if your unit has no green light, the fully charged indication will be when the red light turns iff.
2helpful
3answers
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Top Green Cameras Experts
NOEL
NOEL
Ngoro
Are you a Green Camera Expert? Answer questions, earn points and help others
