D-Link AirPlus DI-524 Wireless Router Logo
Posted on Aug 06, 2009
Router and pc configuration to connect broadband via dsl modem
Sir, I am having problem connecting to BSNL internet through my system. I want to connect to BSNL wirelessly through my desktop. I want to dialup the broadband on demand to take advantage of night unlimited package through this wireless network on my PC only. Please explain step by step process for doing so. Thank you Configuration: Beetel ADSL modem connected to Phone line(through RJ11) Dlink Wireless Router connected to ADSL modem (through RJ45) Intel PC Core2Duo, XP(SP2)OS, PCI Wireless card DLINK(DWA 510
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
619
Points
Sorry i tried to open 192.168.0.50 and it could not display. what is the new IP
2answers
I want to start internet in 4 computers what can i do for. i have a bsnl broadband connention. PLz help me
Hi Friend, In this case I would recommend you to please check if the BSNL modem is the wireless modem or the Wired modem. If it is a wireless modem then you can connect your system wirelessly to internet , provided that the laptop has the wireless card in it.
If it is a wired modem then you can connect your system with the LAN cable to that modem in each slots to get connected to the Internet.
1helpful
Sir The belkin wireless router is not responding in BSNL PPOE broadband connection what is the way to get connected through the ISP of BSNL. murali
IF u are using the BSNL broadband connection, you might be having a modem provided by the BSNL, 7230 model is only a router, it doesnt have modem option so all u have to do is
1. Go to belkin page 192.168.2.1(if u changed the ip address in router, then type the default gateway of the router)
2. Click on connection type
3. Setup as a dynamic connection since the PPPoE is already set on the modem
4. Follow the on-screen instructions
5. Check the internet status, if its still showing as not connected then powercycle the router for 15 sec and then reconnect the cable
Hope it will work
I HAVE A D LINK ADSL MODEM MODEL 502 T. AND ALSO HAVE A BRAOAD BAND INTERNET CONNECTION OF BSNL BUT IT IS NOT WORKING PLEASE ASSIST ME WITH CONFIGURING STEPS
connect the DSL end to the INTERNET port in your modem. then in the ETHERNET ports, connect any computers. then from there you should be able to access internet. if not, follow this to configure
1. in a PC connected to your modem, open a browser and visit http://192.168.0.1
when prompted: username = admin password = admin (or try also <blank> or no password
1helpful
No activity on my new speedstream 4200
Ethernet and DSL lights are indicating you have ADSL available on your line, and that you have computers connected to the router.
What has probably happened is that Optus did not set up the new router with your username and password. Go to thw following website for details on how to setup the modem.
http://help.optuszoo.com.au/help/dsl/connected/windows/optus_modems/speedstream_4200
Manual Modem Settings The Optus DSL Broadband self-installation CD configures all the necessary settings for your DSL Broadband service. You do not need to manually configure your modem if you have run the self-installation CD. While the following information is provided for your reference, using the self-installation CD is the recommended method for configuring your modem.
The Siemens SpeedStream 4200 ADSL modem can use either USB or Ethernet to connect to your computer.
  • If you are connecting via USB you will need to run the self-installation CD to install the USB driver before you connect your modem. The Siemens SpeedStream 4200 ADSL modem supplied by Optus has been customised for the Optus DSL Broadband service. Only the USB driver supplied on the self-installation CD will work with the Optus service. If you do not have the self-installation CD, you can download the latest drivers from the Siemens website.
  • If you are connecting via Ethernet it is possible to manually configure your modem without the self-installation CD. Only a web browser is required.
After connecting your modem there are two key steps to manually configure your modem for the Optus DSL Broadband service:
  • PC settings - Configure your computer's Ethernet network interface.
  • Configure Your Modem - Set the password in your modem's configuration pages.
top
PC Settings Step by step instructions are provided for each of the supported Windows operating systems:
  • Windows 98/Me
  • Windows 2000
  • Windows XP
  • Windows Vista
top
Configure Your Modem To configure your modem settings you must now access the configuration manager using your web browser. This is done by entering the IP address in the address bar of the browser window as follows:
Note: If you are updating the password in your modem, please complete steps 1 to 3 only.
Step 1 of 5
  • Enter http://10.1.1.1 (Default IP address of the Optus Supplied Siemens SpeedStream 4200) to access the modem Configuration software. You may wish to add this page to your Favorites for easy access later.
  • The following modem System Summary screen will appear.
ss4200_home_disconnected.gif Step 2 of 5
  • Click on the word Setup in the green menu of options on the left side of the web page. An expanded set of options will be displayed.
  • Click PPP in the list of options that appeared below the word Setup.
  • The ISP Password page will appear:
  • Replace the default username ([email protected]) with the username provided for you by Optus DSL Broadband.
  • Replace the default password with the password provided by Optus DSL Broadband in the Password field.
  • Note: You will find your Optus DSL Broadband username and password on the letter you received with your self-installation kit.
  • Save these details by clicking the Save Settings button.
Step 3 of 5
  • The next screen will ask you to disconnect and reconnect to the Optus DSL Broadband service.
  • Click the link to return to the System Summary page.
  • Click the Disconnect button to disconnect the modem from the Optus DSL Broadband service. The text on the button will change to Connect.
  • Click Connect to reconnect the modem to the Optus DSL Broadband service.
Step 4 of 5
  • Click the word Mode in the green menu of options on the left side of the web page.
  • Confirm that Optus Bridge is the selected operation mode.
  • If Optus Bridge is not selected click the radio button next to Optus Bridge to select it.
  • Click the Apply button.
  • Click the Reboot button to restart the modem using your saved settings.
  • After about a minute the modem will return to an operational state and connect to the Optus DSL Broadband service.
ss4200_reboot_3.gif Once the modem has rebooted and the ADSL connection has been successfully established the DSL LED indicator will light steady green.
Your modem is now connected to the Optus DSL Broadband service.
2helpful
My dataone WA3002G4 (BSNL) modem is not connecting to internet
You need to configure the pppoe connection in the modem.
2helpful
2answers
How can i configure broadband into two pc?
The best thing to do is to purchase a router so that you could share the internet connection on both systems.
Connection
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
http://in.youtube.com/watch?v=vSAXMO7aNzg
http://tinyurl.com/5tqqhl
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Rakesh
Dell Laptop Expert
1helpful
3answers
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
2answers
Sharing
well that was easy, you havent detailed any problems to rectify.
assuming there is a connectivity problem sharing the broadband connection,
buy a cheap router, or switch, and install between the cable modem and all 4 pcs
2helpful
How to configure paradign modem adsl2 6211-A3-304 in bridge mode for BSNL Dataone Broadband connection
I belive with this modem you will:
1.Access the interface, generally http://192.168.1.1/
2. Go to Advanced on the left.
3. Select WAN.
4. Now you may see several rows of info, look for the one that says PPPoE, and then click edit to the far right.
5. Select Next one time.
6. Here select "BRIDIGING".
7. Click next all the way to the end.
8. Reboot, after you clicked save of course.
This is how you bridge 98% of PPPoE providers with a similar paradign modem.
Of course the next device in line will have to provide your username and password for your DSL connection.
Hope this helps!
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
