Nokia 5130 Cellular Phone Logo
Posted on Aug 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have problem to connect mobile to computer. i receive ppp protocol error.
Anonymous
Level 2:
  • Expert 265 Answers
  • Posted on Aug 06, 2009
Anonymous
Expert
Level 2:
Answers
265
Questions
Helped
74592
Points
936
Reinstall the pc suite and use the latest one
2helpful
3answers
Sir when connect tata photon plus then show on error 734 PPP link is terminated
sir ,
i use the tata photon plus but when i cnnecting it shows error 734 the protocol link was termineted
tip
How do you configure Multilink PPP on Cisco Routers
How do you configure Multilink PPP?
Given that the two sites that are connecting via Multilink PPP communicate with each other and coordinate the configuration, configuring Multilink PPP is easy. Here is a sample configuration of 3E1 circuits being bonded to form a single 6Mb Internet circuit:
controller E1 4/0
framing NO-CRC4
channel-group 1 timeslots 1-31
description Connect to OtherSite#1
controller E1 4/1
framing NO-CRC4
description Connect to OtherSite#2
controller E1 4/2
framing NO-CRC4
description Connect to OtherSite#3
interface Multilink1
ip address 1.1.1.1 255.255.255.252
no cdp enable
ppp multilink
ppp multilink group 1
interface Serial4/0:1
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial4/1:1
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial4/2:1
no ip address
encapsulation ppp
no fair-queue
ppp multilink
This configuration is from a Cisco 7200 router that has Qty 1 Controllers E1 interfaces (plugged into module 4). These E1 controllers create the Serial4/0:1, Serial4/1:1, Serial4/2:1 interfaces that are bound to the multilink group #1, and other serial interfaces (Serial4/3:1, Serial4/4:1 and so on...)
It is the multilink1 interface that is actually the single combined interface that really has the “6Mb” of bandwidth, and that is where you would apply all of your “normal interface configuration” for this 6Mb connection that connects to the Internet. You can see how the multilink 1 interface has an interface number that matches the ppp multilink group. On that multilink 1 interface, you have the IP address for this link, an ACL on the interface, firewall, NAT, or other router interface commands.
By using the multilink interface, you are able to bond all three of these E1 interfaces into a single router interface — very cool!
To verify that your multilink interfaces are up and running, you can use the show ppp multilink command, like this:
Router# show ppp multilink
Multilink1, bundle name is OtherSite
Bundle up for 3w4d, 89/255 load
Receive buffer limit 85344 bytes, frag timeout 1000 ms
10518/6985 fragments/bytes in reassembly list
21651 lost fragments, 3287247349 reordered
17098/8879018 discarded fragments/bytes, 18 lost received
0xA990C7 received sequence, 0x7F6AA8 sent sequence
Member links: 3 active, 0 inactive (max not set, min not set)
Se4/0:1, since 3w4d
Se4/1:1, since 3w4d
Se4/2:1, since 3w4d
Router#
The key to configuring Multilink PPP is the multilink interface, the ppp multilink protocol on each router, and the ppp multilink group x command on each interface. Multilink PPP isn’t a difficult router configuration to set up, and it is extremely valuable when you need multiple circuits bonded into a single circuit from a single provider.
And for sure, you can just add multilink interface to be routed using OSPF, PBR or any other routing protocol.
on Jan 12, 2010 • Computers & Internet
I was having error while connecting my samsung L700 to pc for dial up connection. i was connecting to pc with Airtel Mobile Office and my operating system is windows xp.the error which i was getting is...
FIRST U ASK IN CUSTOMER CARE FOR ID OF YOUR MOBILE FOR INTERNET CONNECTION.AND NOTE THE CODE FOR INTERNET CONNECTION .THEN INSTAL PC STUDIO IN YOUR PC AND THEN INSTALL NETWORK WIZARD AND THEN YOU CAN RUN INTERNET ON YOUR PC THROUGH MOBILE
Error 720 - the connection attempt failed because your computer and the remote computer could not agree on PPP control protocol. Gateway Desktop
To resolve this behavior, follow these steps:
  1. Find out which protocols the RAS server is running, and make sure that the RAS service is installed and configured properly (or ask the Network Administrator to do this).
  2. After you find out which protocols the RAS server is running, make sure that your Windows XP-based computer is running one of the same protocols that the RAS server is running:
    1. Click Start, click Control Panel, and then double-click Network Connections.
    2. Under Virtual Private Network, right-click the VPN connection, and then click Properties.
    3. In the VPN Connection Properties dialog box, click the Networking tab, and make sure that you have a protocol that the RAS server is running.
  3. If you do not have a protocol that the RAS server is running, add the needed protocol:
    1. Click Install, click Protocol, and then click Add.
    2. Click the protocol that you need to install, and then click OK.
    3. Click Close in the VPN Connection Properties dialog box.
Guys!! I hava Karbonn k10 I am using Aircel prepaid in Karanataka. They have launched a scheme for Rs 98/- month free internet both on Mobile and PC. On mobile the internet settings are working fine. I...
For that you've to configure the dial up settings of your Karbon phone. Like NOkia PC suite, they Karbon should have a dial up. PPP link control protocol terminated means that you're password is wrong, or the pack you've taken is expired. Please ask the port number and access name from Aircel Cusomter care. They should provide it and these are needed for dial up.
Thanks
20helpful
3answers
Error 734 ..ppp protocol terminated in .Aircel pocket internet
dear Sir,
I have the mobile handset samsung GM S 3310. I am usuing Aircel Pocket internet in this phone. Surfing net is not a problem from the handset , but unable to connect it to my laptop.
Before dial up, it gives :error 734 ..ppp links protocol terminated. Therefore I Can not connect pc to handset as the dial up connection is not established.
3helpful
3answers
Error 734: PPP Link control protocol was terminated
hi dear, if you are facing the error 734 with n82 using nokia pc suite then i think the solution is delete the extra string in phone and modem option which is in control pannel. the path is control pannel>> phone and modem option>> modem>> select N82 USB modem then click on properties>> advanced tab>> Delete the commend. After that delete the modem settings in handset then connect. it works. just try this . . . . .
1helpful
PPP control protocols
Who ever the ISP is that you are dialling cannot agree on the PPP protocols. In other words your ID to that network is wrong. It does not matter what OS you running. Go back to the ISP you must have one before you can connect. Depending on where you are and who that ISP is you will not and cannot connect until these protocols ie; ID and password have been established. If you have all of those and you thinks there is a problem go to them it sounds like your modem is fine.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
