SOURCE: loud noise while agitating in wash cycle
I have the same problem, loud plastic squeak/grind when agitating only. I'd like to fix it, but have never taken apart a washing machine.
The advice below sounds good but where do you start with "begin dissassembly from the tub down"....etc. Anyone have a good internet resource with images for disassembling this machine?
Thanks.
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
SOURCE: not draining..agitator making a grinding type of
Please keep in mind, I am attempting to diagnose your appliance without being there and with very little information.
Your motor is bad. A Kenmore is a direct drive machine. The motor turns in one direction to wash and the other to pump and spin. The pump turns any time the motor turns. The reason it does not pump the water out while washing is because the pump is running backwards. But when it goes onto rinse or spin, the motor turns the other direction. This is the direction that's bad.
Please rate solution
Testimonial: "Thanks for your input. I took out the pump and it seems to be fine. What is the test for the water pump? Also, what is the cost of a new motor? thanks"
SOURCE: Roper washer RAX4232PQO doesn't agitate or spin
It sounds like you may have a broken motor coupling. This is a common problem that usually occurs through normal wear and tear. Replacement couplers are more resilient and resist breaking much better. If the washer will fill, will not agitate or spin, but will still drain, these are the symptoms of a broken motor coupling. The accompanying noise of the motor engaging and a rattling/grinding sound is also a common symptom. This is a very simple and inexpensive repair. The following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The part number is included in the link I provided. You can purchase a replacement on line at appliancepartspros.com for about $11.
If you have any questions, please let me know. I hope this helps you.
NOTE: Roper is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
SOURCE: WASHING MACHINE FILLS WITH WATER GOES NO FURTHER
not too familiar, but just replaced my lid switch (but that worked) and thru my research I found could also be the belt, so try researching that, sorry could not be more help
