The drain on the wall is called a Stand Pipe. It is designed to be higher than the washing machine so that you do not flood the building every time you do a load of wash. The Machine has a built-in pump to pump the water out of the machine when needed.
You will need to attach a washing machine drain hose to the machine. You should be able to find one at Lowes or Home Depot. https://www.lowes.com/pd/bosch-drain-hose-extension-kit-gray/1000024537?cm_mmc=shp-_-c-_-prd-_-app-_-google-_-pla-_-186-_-sosaccessories-_-1000024537-_-0&kpid&k_clickID=go_625713068_34614756550_111134534590_pla-261169297148_c_9027729&gclid=EAIaIQobChMIwc_2u8_-4AIV9x6tBh1fSA3fEAQYAyABEgJjjPD_BwE
SOURCE: No Drainage on my LG WD-8050F washing machine
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
SOURCE: Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
SOURCE: Bosch Nexxt Premium Washing Machine Drainage Blocked. Cleaned out impeller still not working.
You need to check the drain pump externally to see if the pumping is good Also remove the drain hose clamps and remove the drain hose flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect. Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining. Replacing the pump on a Bosch machine, please check this link for tips:
