Sounds like a loud grinding sound on 3 slot on changer.
SOURCE: 2007 nissan maxima will not load or eject CD's...or even play the
Hi, this is a common issue within car CD changers. the load motor go through lots of trauma during the life span that i usually 3 to 5 years. the load motor operates everything in the changer. it works the load tray and spinning of the disc as well. when this motor is out, the changer will be rendered useless. replacing the load motor will fix this issue or, you can just purchase a new changer and save a lot of money.
SOURCE: Brakes are making loud grinding noise when slowing down to stop or on an incline
Ok, it could be a few things, 1. bad break caliper. 2. if you have ceramic breaks, it could be a cracked brake pad, and if they are not ceramic they can still be cracked. 3. if you drive a lot then it could be that you need new breaks again.. 4. also have your back breaks checked along with the front ones..
SOURCE: Bose 6 cd changer factory installed will not function.
Some people with this issue have had some sucess disconnecting the negative battery cable for 10 minutes to reset the stereo. After re-connecting the battery, the stereo should reset and the error message should clear at which point the CD player should also function. Apart from this, a service call at a dealer or a car stereo repair specialist are the only alternatives. Best of luck.
Greg
SOURCE: cd changer won't play, load, or eject
Had the same problem on our 03 yukon (not the changer but the main head unit) - have a 3rd party waranty and they replaced it. You can get the part for less than 300$ and it's easy to install.
SOURCE: 2002 gmc envoy bose 6cd player does not play, shows player error
how to remove a bose cd/radio from dash of a GMC envoy slt cd's are stuck inside
