How to clean your Dyson Cool AM01 or AM06 desk fan, AM02, AM02 Living, AM02 Mini, AM07, AM07 Living or AM07 Mini tower fan, or AM03 or AM08 pedestal fan.
Your machine may differ to the one shown in the video, but the process for cleaning it will remain the same.
IMPORTANT: Please turn off and unplug your Dyson Cool fan before cleaning it. We recommend using a soft, dry cloth or soft dusting brush to clean the intake holes and loop amplifier. Do not use liquids, polishes or detergents to clean your Dyson Cool fan as this could cause damage not covered under guarantee.
How to assemble and use your new Dyson Cool AM07 Air Multiplier tower fan: adjust the power and oscillation, set the sleep timer and store the remote. The sleep timer can be set between 15 minutes and nine hours.
I've included our Getting Started guide for AM07 below. To disassemble it, you would just need to reverse these steps. To remove the loop amplifier, hold the main body firmly and twist
the loop amplifier anti-clockwise to unlock.This may be a bit stiff if the fan is brand new and hasn't been disassembled before.
I hope this helps, but if you need further guidance from our experts, just give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
The AM07 Tower fan is quick and easy to assemble - our Getting started video guide shows you how:
I hope this helps, but if you have any additional questions you're welcome to give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
If the spray tower is not in place then water will not get to the spray arm for the upper rack. You should be able to re-install the tower. Look for small tabs at the bottom that fit into slots in the mounting. The tabs should snap in or lock when the tower is turned slightly. If the tabs are broken off you should replace the tower. You can use the dishwasher without it but he dishes on the top rack will not get cleaned and the pressure tot he bottom spray arm may be reduced causing dishes to not get completely coean.
The rattly sound means the drive belt has snapped or the protective clutch has slipped. This needs repair by someone who knows how to repair Dysons officially. Sadly its the kind of model that can't be done by the owner.
