Ovens Logo
Martin Denevon Posted on Mar 09, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My stoves diplomat oven wont come on - Stoves Ovens
keith jones
Level 3:
Master:
  • Stoves Master 747 Answers
  • Posted on Mar 20, 2019
keith jones
Stoves Master
Level 3:
Master:
Answers
747
Questions
Helped
314721
Points
1478
Check that it is not in auto or timer mode
Diplomat ADP 3300 oven. How do I reset my oven please?
Question edited for clarity.
'Just Answer' seems to have an answer, but the simple way is to disconnect at the breaker for 30 minutes.
https://www.google.com/search?q=Diplomat+ADP+3300+oven.+How+do+I+reset
Mar 29, 2023 • Ovens
1helpful
Just moved and have diplomat built in single elec oven checked inside but cant find model or serial no. 2 knobs on left all symbols gone some push buttons middle and knob on right numbered 1 to 5
Hello -
Please double check for the model number. It will probably be on a small metal plaque on an edge of the oven door, along the outer edge of the oven opening, or in the oven interior. It could also be on the top of the oven and covered by cabinetry.
Undo the screws that hold the oven in and slide it out 6 inches. You may then find the metal plaque on the top of the oven. You may need the help of another person when you try to pull the oven out, so that the oven does not tilt forward and fall to the floor.
You MAY be able to identify your model of Diplomat oven from one of the images of Diplomat oven control panels here:
https://manuall.co.uk/diplomat-select-620-oven/
Page 6 (PDF document image 7). Note: Use the + icon to enlarge the image.
You may find the image of Diplomat oven knob markings here helpful:
https://www.ukwhitegoods.co.uk/forums/forum/public-support-forums/help-and-support/cooker-and-oven-forum/61498-diplomat-adp4890
Scroll down that page to the post dated 14-12-14 from pslewis333 to see the image.
Once you know which model of Diplomat oven you have, you may be able to find and purchase decals with the proper knob markings for your oven so that you can affix the decals around your oven knobs. Or, you could use heat resistant paint and a small, pointed paint brush to paint the markings on your oven. With either option, I suggest you seal the markings with a heat resistant clear sealant so that cleaning / scrubbing will not erase the markings.
Best wishes.
Jan 24, 2019 • Ovens
Diplomat elite double oven. No manual.how do I set the clock.
Hello -
Apparently, the Diplomat brand of ovens ended production in 2008.
Prior to the end of production, Diplomat was part of the MFI company, with the company's Hygena brand name combined with Diplomat.
I have not yet found a user manual for Diplomat Elite Double oven online.
However, I have found a Hygena Diplomat manual online (free) and the manual has instructions for the clock. The instructions MAY be the same for your oven (I hope.)
See:
https://productmanuals.inbro.net/seeinsidebrochure/Product-Manuals_Hygena-Diplomat-Select-Ovens/Hygena-Diplomat-Select-Ovens/page_1
The clock instructions are on Page 10: Using Your Electronic Minute Minder.
Best wishes.
Apr 07, 2018 • Ovens
My oven wont work
If your gas igniter is bad the gas well not turn on .replace the igniter
Nov 09, 2011 • Ovens
2answers
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Setting on knob of diplomat oven
Im pretty sure that settings mean on the 1 line top element only comes on and 2 lines both elements come on hope this helps
Sep 06, 2009 • Ovens
Diplomat ADP3322/3340 oven, temperature markings rubbed off
You can buy the decals from Ovenlettering.co.uk they send you a sketch of the control panel so you know where to place each number.
Aug 29, 2009 • Ovens
The inner glass panel on my diplomat oven has shattered. What can I do?
My Diplomat Oven Heating element (ELEHY6075) stopped working with the FAN ON combination. I replaced it with a new one and it still does not work with the FAN option. All other combinations do work. What can I do?
Mar 07, 2009 • Ovens
Top Stoves Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a Stoves Oven Expert? Answer questions, earn points and help others
