SOURCE: how to remove starter from 1983 30hp evinrude OMC
I just read up on the removal of your carb, It says to remove the flywheel to get more room, and then the carb, the left side bolt is harder to get to but it can be done. Only get 1/6 turn of the wrench, remove the fuel line, and be careful not to lose any throttle parts. Hope this helps.
Testimonial: "The main problem is NOT knowing how to remove the starter. Thanks in advance, Wayne"
SOURCE: i'm wondering if my 2003 yamaha TTR 125 is a 2
Hi and welcome to FixYa,
It uses a 4-stroke engine.
Good luck and thank you for asking FixYa.
SOURCE: 2 or 4 stroke engine
2 stroke.Fuel/oil ratio is 50/ 1.50 parts fuel,1 part oil.They are a very good reliable motor.Hope this helps
SOURCE: yamaha yz80 2 stroke or a4 stroke
2001 Yamaha YZ80 Specifications
Engine
Engine Type
2-stroke
Displacement
83 cc
Bore x Stroke
47 mm x 47 mm
Compression Ratio
8.2:1
Engine Cooling
Liquid
Carburetion
Carburetor
26mm Mikuni
Transmission
Transmission
6 - speed
Chassis
Wheelbase
49.5 in
Ground Clearance
13.7 in
Seat Height
33.6 in
Fuel Tank Capacity
1.3 gallons
Forks
Forks
33mm Kayaba
Fork Travel
10.8 in
Shock
Shock(s)
Kayaba
Shock Travel
11.1 in
Wheels and Tires
Front Wheel
17 in
Rear Wheel
14 in
Brakes
disk/disk
Other Information
Intended Use
Motocross
Color Scheme
Blue
Cost when new
$3199
