Question about Thomson GE DECT 6.0 Cordless Phone
Can you use a regular ac power converter on your ge digital phone if the original broke?
  • 60 Answers
Another transformer with the exact rating will work fine. If the voltage going into the unit is DC verify that the polarity is correct. Otherwise you can damage the unit.
Dan
Posted on Aug 06, 2009
We have a naxa converter box with a GE universal remote searching for the code
About 17,100 results (0.72 seconds) Search Results
    GE Universal Remote Codes and Instructions ' direcTutor
    www.directutor.com/content/ge-universal-remote-instructions
    Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will ...Missing: naxa
    Apex Digital TV Converter Box DT250 code ' ManualsOnline ...
    tv.manualsonline.com/support/...digital/tv-converter-box/code-1082992
    Nov 15, 2008 - Brock Search data: Universal remote control code apex dv converter... 4 I NEED CODE FOR APEX CONVERTER BOX FOR GE UNIVERSAL ...
    Trouble programming Universal Remote to a DTV Converter ...
    www.fixya.com/.../t2045188-trouble_programming_universal_remote_d...
    Apr 21, 2009 - So I'm trying to program my GE Universal Remote to work with my Digital Stream Converter Box but I can't find the codes to do it... If someone ...
    Control It All With Universal Remote Codes - Digital Landing '
Feb 08, 2016 | GE Televison & Video
How do I turn on my Magnavox digital to analog converter (TB100MW9)
Your Magnavox converter box has or should have its own remote. Your GE universal remote just isn't going to work
Mar 03, 2013 | Televison & Video
Own a GE 29870GE1 telephone with digital answering machine. The digital part works but can't get a dial tone.
Try unplugging the phone from the wall power outlet plug it back after like 3 minutes. Power on and see if you get a dial tone, if not, try reset the unit, once the unit is reset, the problem should be fix. Follow this steps to reset the unit,
Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, this will fix the problem.
Take care.
Sep 23, 2010 | GE 29897GE1 Corded Phone
Can the GE skype phones work with a 220v electric socket?
Depends where you bought it. It is the power adapter you need to be concerned about. The power requirements should be printed on the adapter. They do make power converters for using equipment overseas that you could buy. Just google "220 to 110 power converter" and you'll see what I mean.
Oct 23, 2009 | GE 28300EE1
Replacing Microwave turntable motor
if they are physically alike use it,the units are both120 volt units,you cant operate a 210 volt motor on 120 volts w/o an inverter furthermore it would be 220 volts for that type of motor,its just a production run #
Aug 25, 2009 | Microwave Ovens
My GE phone 27958 just stopped working. I originally thought the cordless handset needed a new battery, but upon replacement that did not help. I found that the base which is plugged into the land line...
check power ?
Is Ac - DC converter pack plugged into power point ?
Is the DC plug plugged into the phone ?
does power point work ?
Check correct dc voltage being produced from the AC - DC power pack converter ?
Isolate other phones on other extensinos to see if uniden is cause or not of no dial tone.
You may have another phone off hook and phone line has timed out .
Jun 11, 2017 | Uniden Cordless Phone
Trouble programming Universal Remote to a DTV Converter Box...
Not a complete solution, but, around the last page (pg. 14) of your converter box manual there are codes listed for universal remotes. I happen to have a Philips remote that is listed. My code to control my dtv box is 0354. It appears that they have all codes listed for all Radioshack model universal remotes. I would suggest getting a Radioshack remote for Your "Digital Stream" (Radioshack) dtv box...
Apr 21, 2009 | GE JASRM24912 Remote Control
Power adapter wire too short to reach outlet.
It is tough to find the right power adaptor with the "right" length cord. Your best bet would be to use an electrical extention cord for the added length you need. "if you can't get the adaptor to the outlet....... take the outlet to the adaptor' !!!!
Dec 26, 2008 | Thomson GE 2.4 GHZ Corded Base / Cordless...
Cordless phone 25881
Sounds like a power problem.
This model of phone will work as a regular corded phone when no ac power is available.
IE the cordless function is only available when you have electricity.
- is the ac adapter plugged into a working outlet.
- is the ac adapter working.
- is the ac adapter pluged into the base.
hope this helps
Nov 30, 2007 | GE 25881EE3 Phone
Thomson GE DECT 6.0 Cordless Phone Logo
52 people viewed this question
Top Thomson Lands Phones Experts
Marvin
Marvin
Van Allen II
Van Allen II
Are you a Thomson Lands Phone Expert? Answer questions, earn points and help others
