Question about RCA Audio Players & Recorders
No sound from my rca rtd317w. I have everything connected even a optical cord..still no sound from speakers on system
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: problem connecting optical connection
What device are you attempting to connect to your receiver? I would check to see if the device you want to connect is sending a digital signal to your receiver. With some dvd players the digital output isn't activated. You will have to go into the menu of the dvd player by using the remote and pressing menu or setup. Find something that involves audio, this setting maybe it PCM or Bitstream. If it is in PCM you will need to change it to bitstream to receive the Dolby Digital sound.
Also you may wish to check what mode the receiver is in. You may have to tell the receiver that you are using a digital input versus an analog one. Your owners manual may be useful with this step.
Let me know how it goes.
BK
Posted on Mar 20, 2008
yooperbud
Weldon Dube'
  • 8637 Answers
SOURCE: not getting sound out of speakers
Go into Control Panel and click on SOUNDS and when the Sound Properties window opens check to see if the speakers are set right.
Hope this helps. Bud
Posted on Jan 19, 2009
memturbo
mark gardner
  • 234 Answers
SOURCE: no sound from xbox to stereo using an optical out from TV to amp
If Im reading this right what you need to do
is hook the audio from the xbox to the stereo system
not to the tv .
Posted on Apr 04, 2009
kafkagoober
SOURCE: hooking up a Bose Lifestyle 30 II to an optical audio output
Actually, you can do this. Just get an optical to RCA converter.
This looks like a good one: http://www.amazon.com/Cables-Go-40019-Optical-Converter/dp/B0002GV876/ref=pd_cp_e_2
Posted on May 31, 2010
Roberto Fabela
  • 85 Answers
SOURCE: I have an LG TV
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Posted on Jan 07, 2011
I have marantz Av surround receiver model SR301 I have tried a lot but I am having sound from only 2 speaker when I put in setero mode but when I put in surround no sound from any speakers I checked all...
First off you will need to do a little bit of trouble shooting. Is the source (dvd, Blu-ray, cable box, etc...) plugged into the receiver with the standard red and white RCA cord or by an optical (toslink-fiber optic) or digital RCA (orange color code). If you are connected with a standard RCA cord then that it your problem and you need buy digital cord that both the source device and the receiver can accept (toslink - http://www.we-supply.com/browse.cfm/optical:-audio/2,779.html or Digital RCA). If the connection is now correct then you need to make your receiver do a "test-tone" to insure that a signal can be sent to every speaker (this is an internal test that just checks the speaker connections). If the tone tone operates correctly then you know the amplifier is functioning. If both of the mentioned things are now done and still not surround output then you need to check the internal menus on your source device and make sure that it does not require you to manual change a setting in the audio menu to make it work (i.e. change from 2-ch 44KHz to 5.1 or 7.1 or Dolby Digital or AC3 or some other surround sound protocol.)
Austin
www.we-supply.com
Aug 08, 2013 | Audio Players & Recorders
My sound bar hooked up directly to my tv has no sound
You may have to go into the Bravia setup procedure and opt to disable its internal speakers
Nov 17, 2012 | Boston Acoustics TVEEM25 TVee Model 25...
I am getting no sound from my rtd317w. Previously I was i don't know what happened
I think they are just junk. Speakers might be ok for awhile but this system is junk.
Aug 12, 2012 | RCA RTD317W Theater System
No sound coming from center channel speaker
check surround sound settings, or another channel" this is your voice speaker, or hook one of the other speakers up to the center channel to see if that center speaker is good , you can also use a battery like a 9 volt to test the center speaker just touch it to the speaker wire momentary. and listen for a cackling noise if it makes a noise it is more than likely good
May 29, 2012 | RCA Rtd317w 5.1 Channel Home Theater...
I have a RCA RTB10223 model, and my problem is I can get the surround sounds to work with a movie in, but its not working with the regular TV. What do I to get it to work?
That is because your movie is in 5.1 surround or better. Over the air and cable broadcasts are not always broudcasted with surround sound, there fore you will not always get it.
Apr 26, 2012 | RCA RTD317W Theater System
The audio keeps going in and out and cuts off. Also I have other devices going into aux in but it doesn't show 5.1 surround it only shows the front L, Front R, and CT speakers in stereo. I want everything...
If you are playing a source that is Stereo such as FM Radio or a CD the sound will not use all 5.1 speakers unless you enable the correct Surround Mode. On the remote there is a button on the lower right of the remote that says SURROUND. You can toggle through the various surround modes with this button the mode you want is Dolby Pro Logic The Pro Logic mode uses the built-in circuit to steer the Left, Center, Right and Mono Surround channel audio signals and uses all five speakers to play both stereo and Dolby Pro Logic program source, such as TV and VCR. You can use this mode with any stereo program source (such as VCR/TV) to enjoy multi-channel sound experience.
Mar 02, 2011 | RCA RTD317W Theater System
Nne help hooking up speakers to entertainment system
If you have a optical out on your dvd player and optical in on the receiver that is the best connection for digital sound, the vcr section will have to be hooked up analog using rca cords
May 26, 2009 | Mintek LCD TV Progressive Scan DVD Player
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
