If something goes wrong with your Dell printer you try to fix it on your own or you take local solution which you often find costly and not 100%. So, we advise that you can get called "One Search Point" provided by us. We offer a direct number that you can call and talk to the Dell representative on the phone and discuss the problem with your Dell printer. Within a minute, your problem will be solved and if it requires further support then you are provided that as well
Dell Printer Support Phone Number.
https://www.onesearchpoint.com/dell-printer-support-phone-number/
SOURCE: Xerox phaser 6180n
Sounds like the memory stick is loose.
If you just received it, that machine has a one year warranty on it.
Call and Xerox will send someone out, or else they will replace it.
Your going to love that printer. WOW what print quality it has.
But your problem most likely was due to shipping and something coming lose.
Call 1-800-835-6100, follow the prompts, they will help make it right.
