If the freezer is working properly but the refrigerator is not cooling, there could be a few different issues causing the problem. Here are a few things you can try to fix the issue:
Please note that it's also possible that there could be other issues causing your refrigerator not to cool, so it may be best to seek the help of a professional if the above steps do not resolve the problem.
SOURCE: Haier Refridgerator
Your freezr drain is blocked or frozen. What you need to do is remove the ice rack then in the front of the freezer you will see 2 or 3 plastic plugs on the freezer floor remove the plugs and there might aso be some 1/4 inch screws farther in on the freezer floor. also remove the back of the back of the freezr and then lift out the bottom floor. under the evaporator you will see a lot of ice or just fod blocing the drain. I will bet its all full of ice. Carefully remove all the ice and hot water will help once you get the buk of it out. The hot water will make sure the drain is not blocked with ice. Once its al clear install in the reverse order and things should be good. This is a common problem with this unit.Good Luck
SOURCE: haier fridge- freezer fine, fridge not getting
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement. Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect. If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply. Thank you.
SOURCE: Upper section of refrig. not cooloing. Remainder
check to make sure the freezer fan is turning. This should be inside the freezer unit at the top. It is probably behind an access panel.
If this fan is not turning, not enough cold air will move to the refrigerator side to keep it cold enough. If the fan has died, it will have to be replaced.
SOURCE: cant find drip pan for haier refrig.top freezer. model#rrtg21pabb any suggestions
http://service.haieramerica.com/Models.aspx?CID=3131
Now let us look at the diagram:
RF-5150-01 is the part number
My Haier LINK
$23
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
