SOURCE: kyocera 1620 error code c-4 000
that code, unfortunately, means your laser unit has went south. you definetly have to call a tech on this as it is quite a job to even get to the laser.
hth
razors
SOURCE: I HAVE KYOCERA KM-1620 MY PROBLEM IS WHEN I
Check that you do not have toner save mode (Eco mode)turned on.Also very damp paper can give this result.
SOURCE: c-4 is showing up on our photocopier, a Kyocera KM
A cover open state is detected during copying or printing .... please switch off the printer and switch on the printer and check it .......
SOURCE: Error E31
this is an error code for slow warm up you should pull the fuser out and check the thermistors and condition of the rollers. sometimes the thermistors get caked in toner so they cant read the temps correct. if you take the unit apart you should be able to detect the toner build up. a soft clothe and some WD40 may be able to clean it off but be ccareful as too rough may clip ther resistor off.
