Seems that either the phone company has cut-off your incoming service (which they do for non-payment), or you have activated a "feature" and need to turn it off.
(phone companies cannot turn off local-outgoing calls for non-payment because that would prevent you from calling 911)
Have you tried calling your landline to see if you hear a message?
A simple call to your Telco Provider would probably resolve this quicker.
SOURCE: no ringer for incoming call
I have seen this issue before and panasonic knows about it. I would contact them directly.
SOURCE: phone doesn't ring on incoming calls
i cannot fix the number of times for the ringer on my vetch phoneset
SOURCE: My BT Verve 450 digital phone set won't ring out /incoming call
My GE cordless handset won't ring when it's on the base charging but it will when I take it off. I've taken off the battery and disconnect the phone from the wall to try to reset it, but it still doesn't ring.
SOURCE: I have philips landline phones. My main phone does
Looks like the basic functions of the phone are correct. Remain the answering machine. Are you sure it can act as an answering machine?
If it can act as answering machine the reason it is not doing so may be the following.
I suggest you try the following
Call you phone. Let it ring at least 10 times. If it can act as an answering machine it will pick up the phone and read the welcome message, because most answering machines (the recent ones at least) answer after 10 rings even if answering function is turned OFF.
The phones that can be answering machines usually do have a display that shows the number of incoming messages, or a LED that flashes to let you know that you have new recorded messages.
SOURCE: landline phone does not ring out when there is an incoming call
incoming calls ringer on corded land line phone no longer works
