Unplug external drive. Restart PC until normal. It will come back. Once back, plug in external drive. Then it is read. You cannot start(boot) PC with a live backup drive connected unless you change the boot order in your PC bios (sometimes called post). If this is not easy for you. Best to plug in after boot up.
SOURCE: Clickfree starts but after about
Dave-
I'm having precisely the same problem. CF works on both of my Vista macines, but won't do anything on my Windows 7 netbook. It loaded the driver, but when I start it up it runs for a few seconds and then NOTHING.
Did you ever find a solution?
Thanks,
Ken
SOURCE: My computer (Dell Inspiron 1525)
Hello.
From Click Free Support:
Ensure that the Clickfree device is plugged directly into your computer.
Once connected, wait 3 minutes to confirm the application did not start as expected.
If the application did not start, open your "My Computer"(XP) or "Computer" (Vista / Windows 7.) and check to see if you have both Clickfree_System and Clickfree_Storage.
Double-click on the Clickfree_System drive or browse the Clickfree_System contents and double click StartMyClickfreeBackup.exe.
If the Clickfreeâ„¢ application starts and begins a backup, then Autorun may be disabled on the computer.
To reenable AutoRun:
FOR XP USERS:
To re-enable Autorun you have to go and download the official Microsoft Windows XP Autorun Repair Wizard. http://www.microsoft.com/downloads/details.aspx?FamilyID=c680a7b6-e8fa-45c4-a171-1b389cfacdad&displaylang=en Please follow the steps outlined by Microsoft on how to use this repair tool.
FOR VISTA USERS:
To re-enable Autorun, go to Control Panel and select Autoplay. Choose the Restore Defaults button in the Autoplay window which is located at the lower left hand corner.
FOR Windows 7 USERS:
To re-enable Autorun, go to Control Panel and select Autoplay (If you do not have the Autoplay option, In the upper right Click on "Category" and select "large icons". You will then be able to select autoplay.) Choose the Restore Defaults button in the Autoplay window which is located at the lower left hand corner.
It's also possible that the ClickFree USB cable is defective. Replace if necessary.
Hope this helps.
SOURCE: My old computer (XP) crashed.
I see. Try to restart your computer, if the computer is completely opened try to check if it worked. If not, try to uninstall it then restart your computer, after restarting re-install it then check it if it will work perfectly.
Thanks.
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts you might have restore it to its defaults Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
hope this helps you
SOURCE: how to transfer files from clickfree hd 1035 to windows 7 computer
click start click on computer to open you should see your drives C: and your other drives cd dvd and your usb drive E: or F: from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to usb drive then drop them example on how to safe data/files to a usb drive
click start all programs accessories open windows explorer navigate to your data
right click on the data select copy navigate back to the usb drive right click select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply
hope this helps you
