Remove the unit and take a look inside the trays as there may be a CD that is jamming the tray as it may not be lying flat on it. Be care not to jar the unit too much as they are very sensitive and shouldn't be moved without tightening the screw that holds everything from moving during transport. There usually is a tiny hole at the front of the tray that you can push in a straightened paper clip and it will manually open the tray.
SOURCE: Sony Mini Hi-Fi Component System (MHC-RG660)
I understand the problem. It should be the relay which is not responding, technically not able to connect the system power supply, you will have to replace the relay. The STK chip should be working fine.
SOURCE: WHAT IS THE DEST ERROR IN SONY AUDIO HI FI SYSTEMS
Disc Error you need to check the CD quality,condition ,& correct CD placement! There is a chance that the CD optic lens needs to be cleaned or replaced or CD lens motor mech. is bad & needs replacement!
SOURCE: Will not play CD's ,press play and the drawer opens
darkie u need to clean your lazer i had seem problem with same model jake here
SOURCE: I need a owners manual for a Sony Mini Hi-Fi
Click Sony Support to download user manual of MHC-GX250
Thanks.
SOURCE: cd player not working
Hello
Replace the laser pickup unit along with its connection wire to main board. OK.
