SOURCE: Sony DCR-DVD 108 disc won't play or record
u tooo have same problem .. i recorded my whole trip on Dvd RW now the camcorder or computer shows fileformat as RAW rather than VR.. plz suggest some solutions.. all i want is my recordings back
SOURCE: C:31:23 error with DCR-PC101 Sony camcoder
Join the other 2,000 plus people at camerahacker.com. with this exact same problem across the entire Sony product line!
some advice:
Although you will find MANY people there that solved their problem by banging the camcorder, HARD, please don't try this first.
First, open it up and take the tape out, VERY CAREFULLY! You may have one or two parts that have come loose in there, specifically a small black roller and a white clip that locks that roller on. You will see pictures of where to look and what to look for on that website. If you turn the camera upside down and shake it, gently, they may well fall out. BE CAREFUL!!! That 2 cent white plastic part and 10 cent roller cost $25 plus shipping from Sony!!! If they're there, don't lose them! Thee is ample explanation on the website about how to re-install them if this is your problem. If not, almost 80% of people on that website fixed it by banging it, give it a try!
btw, sONY REFUSES TO TAKE ANY RESPONSIBILITY FOR THIS OBVIOUS DEFECT! tHEIR SOLUTION IS TO SEND IT IN FOR A MINIMUM $211 REPAIR BILL, BEFORE PARTS! BOYCOTT SONY!
SOURCE: dvd player not loading
I openned mine up and found that the lens carrige was not in the fully retracted position. I pushed it all the way back to the back of the slide. Then I removed the two screws on either side of the spindle support so I could get to the lens. I hit the lens with some compressed air, plugged it in and loaded a disk and it worked like a champ. Listening to some Stevie Ray Vaughn right now!!! And going to watch some movies later. ;)
Good luck, I hope this helps someone.
Wrench
SOURCE: Sony DCR-SR290 camcoder- turns off abruptly
ribbon cable located in the rotating lcd is cut. thats why the shut down its grounding it self out. needs to be replaced. real pain though, cable is serpintined around the part that rotates. sony does flat rate for prob. about 250 US
SOURCE: i have a sony handycam dcr-dvd 340 which is displaying recording
Format mini DVD disk with camera Menu format option.
This will solve your problem.
