SOURCE: bissell power force
turn vac over, take of the access plate covering the brush roll, may be 2 to 4 screw. Then you can get to the brush roll and belt. It uses a Bissell Style 7 belt.
SOURCE: bissell 12 amp model 6850
That would be the motor shaft, if it has power to it and is froze up, you will have to replace the motor.
SOURCE: bissell clearview force 12 amps
Here is their number, they can tell you who to call in your area.
End User/Consumer Services Phone Number:
(800) 237-7691
SOURCE: how to use bissell proheat clearview 12 amps rug
Here is a user guide, and it will show you how to use it. just click and read. its a PDF file. you might need adobe to look at it. It is a free download.
http://www.bissell.com/images/UserGuides/7901_1008.pdf
Hope this helps you from sawdust
SOURCE: my bissell clearview 12 amp vacuum's motor races.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rrugf
http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50&cid=ccsocial
https://www.bissell.com/replacement-vacu...
