The left hinge that connects the dust cover to the turntable snapped. Gemini pt2400 It was a sad moment. Does anyone have any leads on a replacement?
SOURCE: need to replace the light
Hi Scotty
Just go for it man... The light is a pop assembly, so you will have to go in from the bottom to get access to it. Searched for a service manual to link to you, but not much out there. Do you have a multimeter to do a few DC checks?
SOURCE: would it be extraordinarily difficult to replace
I,ve never done a gemini pt-2000 but i've done a technics 12/10 & trust me mate it's a proper pane in the arse.
But like i said I've never done a pt-2000....
SOURCE: I'm missing the tonearm counterweight for a Gemini
hi,
i'm too missing the tonearm counterweight for my Gemini TT01. if you haven't figuered out where to buy one, do you know at least what is the weight that is needed to counter the weight of the tonearm or how to measure the tonearm so as to make a counterweight of my own???
thank you in advance
SOURCE: How to remove the platter in Gemini PT-2400
hi,
firs of all remove from the mains. pull out the rubber bed over the platter. check whether there is any lock washer in the center shaft. if have remove it. if not its ok. now pull the platter towards upside by putting the fingers in to the holes provided on the platter. remember pull using ur two hands in opposite direction.
ok
