Dishwashers Logo
ken bailey Posted on Feb 27, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool dishwasher. 80% of lights on the control panel are out
Steve Novak
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 153 Answers
  • Posted on Oct 05, 2020
Steve Novak
Expert
Level 2:
Mentor:
Answers
153
Questions
0
Helped
25412
Points
385
The connector ribbon cable oxidizes connecting the keypad, replace the keypad!
4 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 08, 2008
SOURCE: Maytag Dishwash - No lights will light up on the control panel
first off ck the breakers ofr tripped breaker, next remove lower acess panel and on right side is main wire connection remove box cover and make sure connection is good. ck fro 110 v there if not you got an electrical issue. next would be to check the door switch assy's.
Anonymous
  • 188 Answers
  • Posted on Mar 12, 2009
SOURCE: Whirlpool GU2500XTP dishwasher went dead in mid-cycle.
"Wondering if this model has had reliability issues with the circuit card." ...If by circuit card you mean the electronic control board, that part number is used in many other models as well. In my experience with these control boards, I believe they have a low failure rate.
Make these checks if you haven't done so yet...
Check for 120V (breaker). Look for loose/shorted wiring connection at the dishwasher's junction box. Check all wiring connections to the control panel, electronic control and thermal fuse. Test the continuity of the thermal fuse (part # 8193762). If that's ok, you have already replaced the control panel so the problem is likely with the electronic control board (part # 8564546).
Good luck.
James Black
  • 33 Answers
  • Posted on Sep 12, 2009
SOURCE: Whirlpool GU1500 XTLS Dishwasher, need control panel part number
Just go to this site and you will find the part you are looking for.
http://tiny.cc/z5Sy6
Testimonial: "Love that he told me what part he thinks it is but why is ther 3 different parts that look exactly the same on this page he sent me to. Very Confusing"
gizmothec85039
Greg Hoffman
  • 147 Answers
  • Posted on Jul 02, 2015
SOURCE: Meiko dv 80 t dishwasher control panel's all lights are flashing what can be problem in side the machine please.send answer as soon as possible thank you.
2answers
Clean light blinks on whirlpool dishwasher won't run
If you aren't sure whether Control Lock is on, press a cycle button on the keypad. If Control Lock is on, the light will blink three times.
Turning off Control Lock:
  1. Press and hold the Lock Button for four seconds. The lock light will disappear.
  2. Once off, you should be able to start your wash cycle.
Note: If Sleep Mode is on, turn that off first, then turn off Control Lock.
Like many other electronics, you may need to reset the dishwasher control panel by turning it off, waiting, then turning it back on.
  1. Press the OFF button.
  2. Disconnect the dishwasher from its power source by unplugging it or by turning the circuit breaker off at the electric panel.
  3. Once disconnected, wait one minute, and turn the power back on.
I have a Whirlpool Quiet Partner Two dishwasher. The rinse only light & quick wash light constantly blink and I can't run it, none of the buttons will work. Is there a way I can reset my dishwasher?
This generally means the control panel is no longer working and must be replaced. That's the entire plastic assembly at the top of the door, in which the buttons reside. Disconnect power first, remove screws inside the door which hold the panel in place. Unplug power connectors, remove circuit board control board. Find dishwasher model number and search parts for that model. The part is pricey, more than $100 last time I replaced mine. Install control board into new panel, make power connection. Reassemble door. Good to go.
The hi temp light keeps flashing on my whirlpool dishwasher.
Not sure which particular model you have got. If turning off the mains power off and on is not helping then you will need to reset the controller. "press your "Normal" button then your "Heated Dry" button alternatively several times (quickly). This should reset the control panel and allow you to resume normal functioning."
Read more: http://forum.appliancepartspros.com/dishwasher-repair/11043-control-panel-lights-blinking.html#ixzz2psYY7aFn
Error 1 on kenwood dishwasher
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
3helpful
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Thanks.
1helpful
Problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
