SOURCE: H2 Error
You have a thermistor open. That means that the device that reads the temperature in the fusing unit, has broken. You will need to replace the fusing unit to fix this problem. You could try a Sim 14 reset. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit
temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING
ON MACHINE***
You have to reset fuser errors with simulation 14.
SM
5-1 should turn the lamp on. If lamp blinks on and off it is the
thermistor, if it does not it is the lamp, but check the contacts on
the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective
replace.
it is a heater code. The thermostat has blown and resetting the code could cause a fire, but it probably won't do anything, the part will need to be replaced
SOURCE: sharp 5320 H2 error code
this is a fuser error message. You must fix the problem causing the fuser to post an error. Then clear the message.
SOURCE: sharp ar-m160 h2 error code
chack the fusing units the thermistor is open
&thermistor abnormality chack the harness and the
connector between the thermistor and the pwb
use simulation mode(# interaput c interaput )
preas the 14 toclear the self diagnostc dis play
