Computers & Internet Logo
v
vipin Posted on Feb 27, 2019
I am facing a CH error in display of UPS with Beep sound can you please help me to resolve it i also complained against the issue in microtek care
  • Anonymous Jul 09, 2021
    LT cmdr, Spook mind melds , uPS , firmware designer, and see's CLOUD form and ,CH = charge failure?
    sorry wild guessing... do not look at the man behind the curtain.
    click your heels 3 times and say :"call microtek on the horn"
    that would mean?
    1: batteries are toast (1 TO 3 YEARS LIFE)
    2: wired connections to them rusty (common)
    3:CHARGER IS DEAD INSIDE OR FUSE BLOW TO SAME.
    AVOID THE 350V INSIDE AND NEVER SHORT THE BATTERIES, FOR SURE the big types with bolted lugs seen on cars. we use insulated wrenches or BOOM (use gloves and googles as acid ruptures wreck EYES
    remember I WARNED YOU.
    some cheap home week (500VA ) HAVE Simple snap out battery packs, no bolts no lugs with screws)
    NO UPS TOLD so answers are all generic,
    if super confused, post a photo of it. and we love to play that game too.
Ansuman Mahapatra
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 09, 2021
Ansuman Mahapatra
Contributor
Level 1:
Answers
Questions
0
Helped
3003
Points
    hyjacking Vpins post
    did you put in new batteries first, #1 cause of all failures is that.
    NO microtek, model told at all. that is why zero hope for 2 long years. yah think?
    topic is UPS , an AC power backup, system. for when lights go out.(AC power to the home ,etc)
    I guess you are in India , and we have no microtek here USA.
    i see they have no SUPPORT option on theIR web site ( vary bad that, zero support)
    I see no manuals, there, why? Id never by a $1 light bulb from them.
    I use, maker APC, here, they have huge support .
    for help here, using UPS on Computers only.
    look at the UPS and find the service tag and then tell helpers what model it is.
    or google this
    Microtek model xyz123, UPS , manual
    or call them on the horn (cell,etc) and ask them directly.
    hint never operate any UPS with zero manuals in your possession or you will suffer protracted down times.
    be a "boy scout" proactive, have a manual and 1 spare battery (pack) ready if UPS matters.
    models matter, YMMM your model mainly matters.
    like sebz-1100
    or ss1660,
    or XP1400,
    LOOK HERE, SEE WHY NO MAN ON EARTH CAN GUESS;.
    https://duckduckgo.com/?q=microtek+ups+%...
    SOME MAKERS OF UPS have no real manual, this is because they do not want NOOBS getting electrocuted.
    with 353volts inside, very deadly ! even 12vdc shorted can blind you, (some do 500amps easy shorted) boom.
    so they tell you we only do real human to human service calls.
    but your maker has zero PDF support,
    the vast model;s are for KW needs, power levels. home and business class.
    their web site is 99.9% hype,
5 Related Answers
Anonymous
  • 2785 Answers
  • Posted on Jun 28, 2008
SOURCE: microtek ups,no backup,pc restarts on voltage fluctuation
your ups needs servicing
Anonymous
  • 322 Answers
  • Posted on May 15, 2009
SOURCE: My Nokia 7610 screen display
try reformatting it.
Anonymous
  • 161 Answers
  • Posted on Jan 19, 2010
SOURCE: A beep sound is coming continuously during boot
this sound may be from your keyboard one of key be stick to make sure and find this key you need download this soft to test your keyboard.
http://www.passmark.com/products/keytest.htm
may be help u solve ur problem
Anonymous
  • 1219 Answers
  • Posted on Jun 14, 2010
SOURCE: (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server: I have also facing the same problem of Error code ...
So, you need to do next:
Because of statics and plastic bottle, the toner is collected on bottle neck, where is two circles. Even if bottle isnt full but the neck of bottle is dirty the error will occure.
Clean the neck with dry cloath, and then with some antistatic detergent, this will take care of the bottle.
But more permanent solution is to disconnect the waste toner sensor. You will see it above the waste toner bottle.Its a white connector with wires. Pull it out.
But then you need to take a very good care of amount of waste toner in bottle, because if it gets too full it could broke the waste toner gears. So that means that you must every time when you replace the drum, empty the bottle too.
Anonymous
  • 113 Answers
  • Posted on Aug 12, 2011
SOURCE: I am using Sony Vaio
Hi....Just check the sound with stereo headset.If it is working properly ,right speaker has to be replaced.If the situation persist same before,you may have to check the motherboard .
1helpful
APC SILICON 40KW Ups.. on statrting ups it doesnt goes further to any screen display,Red ALaram LED is on(no blinking etc),. can any one guide?
apc silicon 40kw ups,1.check if input phases are complete.2.do a phase swap like changing the phase sequence and see if it will complain sequence error.3.after start-up u need to do a dc start-up,the dc bus is +360/-360vdc and after the dc bud is completed you need to press the green botten to power the inverter.if it doesnt do the dc start-up then go to the log and see what it complains about.write out the complain on the log and forward it to me.08082245266.engnr festus.
Whenever i switch on my UPS(MICROTEK) after some time the power comes to my extention /spikes ,moreover the green light blinks constantly with no beep sound. What is the reason behind that?Do i have to...
Dear qautamsaha6,
Hello and welcome to FixYa!
With this UPS unit, if the battery were the issue, the replace battery light would be on. In this case it would appear that this UPS has taken a hit that killed the charge/power circuit. i advide replace ment of the unit.
Have a nice day!
5helpful
3answers
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Microtek dual ups battery
yeah, you need to replace the battery with the same kind of battery installed in it or you may consult with the technical support of microtek nearest you.
8helpful
3answers
Getting red light and continuously beep sound to my UPS(Frontech)
hi
If it is showing the red light and continuous beep it shows that the battery is completely gone.
You can buy a battery and replace it by yourself.
Or get it to a professional to change the battery.
you need not replace the whole UPS its just a battery problem.
Thank you
26helpful
" CH"
if ch error is displayed on your samsung ac . press and hold the up and down arrow mark(in the ac control pannel and not in remote ) simultaneously for few sec untill u get a beep sound from it ... this is a default seting to remind u to clean the air filter
Top Microtek Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
