42" Panasonic Viera Plasma Tv. It has these white star-like dots that float across the screen from left to right. Just started doing it out of the blue. Even when the cable box is turned off and the tv is on they are still there on the black screen so it's not the cable signal. Tried turning it off and back on but they're still there. Any ideas?
SOURCE: 42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
SOURCE: Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
SOURCE: Panasonic viera
1.You may have the magnet of a speaker too close to the TV.
2.Turn off other electrical devices in the house one at a time.
3.Faulty cable.
Puzzler.
SOURCE: plasma TV with vertical lines
Help! My Plasma by Magnavox is putting black verticle lines on the right side of the screen - comes and goes - and I replaced the entire Direct TV-HD unit - wires, everything - and had TV company repair - and it still came back. The TV repair refuses to take TV back because it does not show up when they come. Although I videotaped it and showed them which has the date and time - they still refused to take it - and tried to get me to sign a paper saying it was working while they were there - which of course I refused to sign - so they left and nastily said they will not be back-find someone else. I still have the lines - and do not know what to do! Can anyone help?
Your Cost: $640.79
