Question about KitchenAid Microwave Ovens
The display light on my 1 year old kitchen aid microwave has gone out, but the microwave still works. Do I need a whole new panel or just a light bulb? Model KMHS120ESS
    Top Expert:
  • KitchenAid Master
  • 64,733 Answers
Think use brain contact mfg's website (ASK) them or Google it
Posted on Feb 26, 2019
6ya staff
SOURCE:
yalmer
Hjalmer Lamminen
  • 552 Answers
SOURCE: Broken Display KCMS145JSS-1
http://www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=%60Bkitchenaid
http://www.howstuffworks.com
Posted on Mar 13, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: How do you replace the fuse in a microwave oven.
Be sure the oven is unplugged or the breaker is off.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Let us know if we can help further.
Posted on Jun 06, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Microwave turns on & control panel is frozen. F2&PAN error codes
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number (KHMS155LWH1 without dashes) from the tag on the oven here.
Posted on Jun 11, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You should be able to get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
Posted on Aug 04, 2009
Anonymous
  • 998 Answers
SOURCE: Microwave Totally stopped - nothing turns on HELP Needed
check fuse
Posted on Aug 08, 2009
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
The display is too dim to read. what can I do?
Depends if it was dim when new then not a lot you can do
if it has gone dim , you have 2 options
1 unplug it and put plug in front of oven door,then remove all cabinet screws.locate the display control printed circuit (under display)take photo of wiring with phone to aid reassembly ,unplug and remove printed circuit board screws and board,clean display screen and window ,if was clear then either obtain replacement panel or take panel into radio or electronic repair shop and have them check and replace any poor electrolytic capacitors, this usually cures older ovens ,but if 6 0r 7 years old displays themselves dim and need replacing.ps if good at soldering just note these capacitor values uf and voltage and obtain at maplin and replace all observing polarity when fitting
Jan 11, 2015 | Microwave Ovens
Microwave - Kitchen Aid KHHS179LSS4 ERROR CODE -
Hello there Jerry
Sorry it took so long getting back to you i just finished moving into my new home and just got my internet today ok ill send you a troubleshooting steps
However this error code usually turn out to be a problem with the controle panel of the microwave and the only fix for these is to replace the part ok i will post the rest of the troubleshooting steps in a following comment ok
Best regards Mike
Jan 23, 2012 | Microwave Ovens
How do i remove the halogen light in my micowave
I have a similar Kitchen Aid model. The little light inside my unit also went out. I called Kitchen Aid and they scheduled a tech to come out to change it. He said the only way to get to it is to pull the unit out from the wall (it's a built in unit). $150.00 bucks later I had a light for about another year before it burned out too. Needless to say, the heck with it, I don't need the light that bad.
Nov 16, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
I have a Sharp R-305KS stainless microwave. It is about 1 year old and until recently, I haven't had any problems with it. About two weeks ago the cancel button on the front panel started to work...
Hi and welcome to FixYa, I am Kelly.
This microwave has a 1 year warranty. You are going to need a new keypad to correct your symptom. Let Sharp pay for it.
http://www.sharpusa.com/~/media/15710197EE3140AD888B896ACDC912DD.ashx
(Choose "open" ) Then go to page 2 for contact information. Page 3 sates Parts and Labor 1 year.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Sharp R305KS Microwave Oven
No Power at all
If it came installed in the house, it may have its own breaker switch. I'd check the breaker. Have any outlets in the kitchen gone out as well? This would support the breaker switch idea.
Hope this helps.
Jan 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No Power - Emerson MW8773SL Microwave
LOOKK FOR FUSE UNDER SCREWED IN PANEL!
Dec 10, 2008 | Emerson MW8775W Microwave Oven
Microwave Ovens Logo
53 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
