Cleaned pump several times. works then displays 'check pump' after use. Is there a filter I am not seeing at front of machine ??
SOURCE: LG WM2277H - OE error
THE ABOVE SOLUTION WORKED LIKE A CHARM. IT WAS A TINY BONE STUCK IN THE PROPELLER BLADES. THANKS FOR THE SOLUTION!!!!!!!!
SOURCE: Bosch Nexxt DLX washer-can't open round panel in lower front
Its easy to do, and no you dont need to be a tech. I use a small screww driver w/ the tip in the hole push it left or right until it comes loose. then just un screw the pump cover. be careful the edges are razor sharp.
SOURCE: Press the ?filter? button to turn off the indicator light !!!
Try pressing and hold the filter button for about 15 seconds. See if this works for you. If I can help further, I am here......Eric Campion
SOURCE: Dryer not working, indicates "lint
This is a common complaint with this dryer.The probe generating this problem,is at fault.It likely has a film on it,from the dryer sheets.Remove the lint screen,and wipe down the probe that sticks into the air box.Should fix the problem,if not ,replace the probe.
SOURCE: Bosch washing machine logixx 8 front loader error
I forbindelse med start af vaskeprogram melder maskinenen F37 fejl? hvad betyder det?
Check Filter Indicator
The ability of any humidifier to efficiently supply humidity output relies heavily on the
condition of the filter. As the filter loads with impurities it gradually loses its wicking
capability. When this happens, moisture output is reduced and the humidifier has to work
longer to satisfy the selected setting. This humidifier has a check filter reminder timed to
appear after 720 hours of operation. When the Check Filter (CF) message is displayed,
disconnect the power cord and check the condition of the filter. If a build-up of deposits or
severe discoloration is evident replace the filter to restore maximum efficiency. The CF
message is reset when the humidifier is plugged back in.
