Vehicle Parts & Accessories Logo
A
Anonymous Posted on Feb 22, 2019
How to turn off alarm system. Does not work when I push the alarm button.
Here2HelpYou
Level 3:
Master:
  • Master 592 Answers
  • Posted on Feb 23, 2019
Here2HelpYou
Master
Level 3:
Master:
Answers
592
Questions
0
Helped
152673
Points
4122
I'm including link of popular solutions, but when this happens rbme I just stick the key in the ignition, if that doesn't stop the alarm then go ahead and start it up, that should do it.
https://m.wikihow.com/Reset-a-Factory-Car-Alarm
If anyone finds this helpful please let me know by clicking the green "helpful" icon below. A few words in a testimonial or recommendation is the best compliment I could receive. I strive to help answer questions in a cost effective manner that addresses and fixes the problem so that you can move on to the more enjoyable parts of life. Any/All Feedback is Appreciated,Thanks!
I lost remotes,how do i bypass alarm?
Locate the valet/override switch. You may have a push button LED or, it may be located under the drivers side of dash. Turn igniton on press and release push to manually override alarm. Turn ignition off then, back on. Press and hold push button for approximately 5 seconds to put alarm in valet.
tip
DEI viper alarm acting up? cant get alarm to work, Read on
ALARM TROUBLESHOOTING TIPS
(This guide may provide help on temporarily disabling a alarm until a repair can be made)
If your alarm goes off constantly or does not armed by itself:
Does the alarm arm and disarm properly? If it does proceed, if it doesn't, then have it checked by your installer.
1. Check and make sure your dome light is not staying on. If it is make sure all doors are closed and/or the dome
light switch is not turned on.
2. Check your sensor. Make sure they are not too sensitive. They can cause false alarm and also cause the system
not to arm by itself.
3. The alarm current sensing might be detecting voltage drop from the battery of the car or current draw from an
equipment (maybe left on).
If your car won't start check the following:
1. Does the alarm arm and disarm properly. If it does chances are is not the alarm.
2. When you try to start the car the alarm goes off.. It could be your battery.
3. Try to start no sound, nothing lights up, alarm doesn't work. It could be a loose battery terminal or dead battery.
4. Everything lights up, alarm works fine, but car still won't start. I could be a bad starter, starter disable in the alarm
or check and make sure the car is in "PARK" or press the clutch all the way down to the floor.
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
To de-activate the Valet Mode do the following:
There is a push button or toggle switch to enable the alarm (to disengage the valet mode). Without knowing where this switch is you won't be able to reconnect the alarm.
2. Flip the toggle or hold the push button for at least 1 seconds no more than 2 seconds on most DEI products,
keep it pressed in.
3. Turn the ignition off.
4. The LED. light will be off.
5. Release the push button. If you have a toggle leave it alone as described in step 2.
For more info visit us online at www.lesscoelectronics.com or our weekly deals at www.lesscosales.com
We also offer free live chat too!
on Jul 29, 2010 • Car Audio & Video
1helpful
I bought my car used with an aftermarket prestige alarm w/ remote start. Battery and alternator went bad. They have been replaced. The car will not turn on and alarm remote is not working.
Locate a black push button switch under the dash or near the drivers side kick panel (older model), or the alarm has a push button LED light(newer model) or the Valet switch is in the antenna(newest model). Turn the ignition on, press and release the switch one time. This should disarm the alarm.
For programming: turn ignition on, press and release the valet switch three times: you will hear one chirp from the alarm, press the lock button on the remote. Press and release the valet one time, you will hear two chirps from the alarm, press the unlock button on the remote. Repeat as necessary. Turn igniton off to exit programming. Test remote for proper functioning.
3helpful
How to disable alarm system. The alarm went off
okay, this alarm reset is done by turning the key on and pushing the reset button a few times, you will need to try this a few times to get the correct number of pushes,for example turn key on and quickly push 3 times and if that doesnt work retrey it and push it 4 times, take note that every time you try you need to turn key off and then on again before you push reset button,i know it can be set to 1- 2 -3 or 4 pushes to reset, this is programed at the time of install, most installer dont set it or tell you so you will need to try all four. good day.
2helpful
I have a AW60448W stopwatch that I can't get the alarms to turn off.
AW60448W Stopwatch
Okay, now you have an excellent Stopwatch but don't know how to set it up. Well, I had the same problem but a friend of mine wanted one also and after I bought it for him, he being an old guy, could not read the small print that came with the Stopwatch. I have gone to the trouble of typing it up and you can benefit from this.
Now I don't expect you will send me any donation/money but if the mood strikes you, I will accept no more than $3.00 cash.
Ron Gray
9540 C.R. 13 North
St. Augustine, FL
32092-2602
E-Mail: [email protected] if you have questions.
Your Welcome
S1-Button: LAP/RESET
S2-Button: START/STOP
S3-Button: MODE
LIGHT BUTTON: Needs no explanation
LIGHT BUTTON:
The watch is equipped with an electroluminescence (EL) backlight, which can be activated by pressing the EL button. The LCD will light up for three (3) seconds.
CONTROL OF WATCHES:
Normal Display: Hour, Minute, Second and Day of week.
Push of S1-Button: Display shows alarm time in Hour and Minute.
Push of S2-Button: Month, Date and Day of week.
Push of S3-Button: For change of Function.
ALARM OF CHIME ON/OFF:
In normal time: Hold S1-Button and Display shows alarm time in Hour and Minute.
Hourly Chime: While holding S1-Button down, press S3-Button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
Alarm: While holding S1-Button down, press S2-Button. Alarm icon will display when alarm is on. Icon will disappear when alarm is off. Release S1-Button and Display changes to normal time immediately.
CHRONOGRAPH MODE:
In normal time, Push S3-Button, chronograph Function will be set.
Start/Stop: Push S2-Button, it operated in cumulative counting up to 1/100 second.
Split Time: Change to Split Time from chronograph time display is performed by pressing S1-Button while chronograph is counting.
Chronograph keeps counting while Split Time is displayed. Push S1-Button again to return to Chronograph Time display.
Reset: Push S2-Button to stop counting and then push S1-Button.
ALARM TIME SETTING:
In normal time, push S3-Button twice to get into Alarm Setting Mode. Monday flag + Hour digits will flash, which is advanced through depression of S2-Button.
1 x Push of S1-Button: Monday flag + Minute digits of the Alarm Time will flash, which is advanced as above.
Push of S3-Button: Display change to normal time again.
NORMAL TIME SETTING:
In normal time, push S3-Button three (3) times. Tuesday flag + second digits will flash. Push S2-Button and Second will be reset to zero (0).
1 x Push of S1-Button: Minute digits flash and advance by depression of S2-Button.
2 x Push of S1-Button: Hour digits flash and advance as above.
3 x Push of S1-Button: Date digits flash and advance as above.
4 x Push of S1-Button: Month digits flash and advance as above.
5 x Push of S1-Button: Flag of weekday flashes and advance as above.
Push of S1-Button and second will start for setting again.
If S3-Button is pushed during anytime change Normal Time will resume on display.
12/24 HOURS REVERSAL OPTION:
You have the possibility to change from 12 to 24 hour system, when adjusting the hours of the normal time (description please see above) one after the other the hours are displayed in the 12 hour system, then in the 24 hour system and then again the 12 hour system, i.e. please push S2-Button so many times, that the hour is displayed in the required system. In the 12 hour system hours are identified by "A" from 24:00-12:00 and with "P" for 12:00-24:00 whereas in the 24 hour system all hours are identified with "H".
ALARM TEST:
Hold S1-Button and then hold S2-Button together. Alarm will "Beep" and Alarm sounded.
ALARM SOUND OFF:
To turn off beeping when Alarm goes off press S1-Button or S2-Button.
For some model, press Light Button also can turn off beeping when Alarm goes off.
Alarm function with 4 to 5 minutes snooze by press S2-Button.
Lifetime Limited Warranty
The Geneva Watch Group warranties that it will repair any failure due to defects in material and/or workmanship free of charge. This warranty is by Geneva Watch Group, not by the dealer from whom it was purchased. This limited warranty does not cover replacement of crystal, battery, band, strap or case. Geneva Watch Group reserves the right to replace any and all inside components in lieu of repair. This warranty does not cover any failure to function properly due to misuse such as water immersion or sever shock. If your watch ever needs service, wrap it carefully in tissue paper or a similar soft material and pack it in a mailing carton. Send it via insured Parcel Post to:
47440 Michigan Ave.
Suite 130
Canton, Michigan 48188
U.S.A.
Include a brief note explaining what is wrong. Be sure to print your name and address clearly. Enclose $7.00 to cover the cost of return postage and handling.
"Do Not send cash or checks. Only Money Orders, Master Card or Visa are accepted."
Card Holder Name: _________________________________________
M. C. ___________Visa______________________________________
Account Number: ___________________________________________
Expiration Date: _____________________________________________
visit us at www.advantagegroupinc.com
AG9936-00
To set Time:
1) Press "MODE" button until Time is displayed.
2) Press and hold "LAP/RESET" button until seconds display starts flashing.
3) Press "START/STOP" button to change selected entry.
4) Press "MODE" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "LAP/RESET" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "LAP/RESET" button until minutes display starts flashing.
4) Press "MODE" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "LAP/RESET" once you are done to set the alarm.
To toggle Alarm Sounds ON and OFF:
1) Press "MODE" button until ALM is displayed
2) Press "START/STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "START/STOP" button on the watch.
How do I turn off the hourly chime on a Wal-Mart Athletic Works stopwatch?
The way to do it is push the "light" button, then the "set" button. If the hourly chime is active, the days indicators will all be highlighted, if it's disabled, they will be turned off too. Basically it's the same as turning the alarm on/off, but instead of using the "start/stop" button, you use the "set button".
Dec 28, 2010 • Watches
93 mercury sable battery died now alarm won't allow me to start car!
use the key to lock and then unlock the driver door, this should allow car to start,it shuts alarm off. if its aftermarket alarm system then locate the push button under the dash, its a little push button usaually red, turn key on and quickly push and release this button 4 to 5 times.
Alarm is stuck in valet mode
This will work for many alarms, but not all:
Locate valet push button, may be hidden on or under dash somewhere. Turn on ignition, doesn't have to be started. Then push and hold valet button for a few seconds. Most alarms will chirp to confirm operation was a success.
DEI products require a slightly different procedure, and drivers door has to be open.
Some can be done through the remote.
Model of alarm will help alot, or FCC ID from back of remote. DC
2helpful
Alarm stopped working
sounds like the system is in valet mode.
locate a switch under dash if a toggle switch is found then turn on key and flip switch. turn key off if led is off try alarm.
If a push button switch is found then turn ignition on and press the switch for 10 seconds, then turn key off iff led is off try alarm.
1helpful
Problem with my viper alarm system on my 98' odyssey
first, you need to manuslly disarm the alarm. open driver's door, put key in ignition, turn on ignition, an then within 10 seconds push the valet/program button for a couple of seconds. (it is the little spring loaded push button that they installed with your system. probably in the kick panel or under dash
Turn off alarm
With the power off, push the alarm button twice and the clock symbol should go out. This means the alarm is off. Also when the alarm is on and the power is off, you can push the function button to select nothing (buzzer), cd or radio.
Hope it helps, I am trying to find out how to reset the default volume from 17 which is way too loud
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
