Check speaker connections sensing issue
SOURCE: NAD 712 Stereo Receiver
the lamps i use on all NAD displays(and have done since the early 1990's) last heaps longer.You can get them from RS components in your country. They are a 14v 37ma type, and seem to last. Never had any come back for replacement again. P/N 351-9585. Increasing the ballast resistor where fitted by 25% in valua also helps preserve them
SOURCE: Can't record
I have the same problem!
Apparently their is a ribbon cable on the tape drive mechanism that tore because of samsung's crappy design that ribbon cable sends a signal form the tape protection switch.
Since the ribbon is torn and the circuit open the camera thinks the protection on the tape is on
if any one knows where i can buy samsung parts, please let me know
SOURCE: Remove the write protection on 2GB USB Kingston Data Traveler 100
Found this on Kingston site, doesn't help much but may point you in the right direction.
Unfortunately this unit does not have any security or write protection feature. If you receive a write protection message with this drive, check for the following:
SOURCE: how to remove write protection from sandisk cruzer flash drive
how do I remove write protection on my cruzer 2GB thumb drive
