To clarify, the ADF has two positions; ready position(roller up and waiting for document to be inserted) and feed position(roller down and feeding document into ADF). When the document is inserted into ADF and "copy" is pressed, the ADF begins turning rollers, however the roller stays up in the air in the "ready position" while turning and doesn't drop down into the "feed position" to pull the documents through. When the ADF cover is opened and the gears are turned manually(by hand), the slots align and the roller drops down onto the cork pad into the "feed position". It does not drop down automatically. Is something misaligned? gears perhaps?
I would start with putting in a new ADF kit.
https://www.printersupplies.com/p-ljm2727adfpjk.html
SOURCE: Document not moving all the way thru ADF.
The roller and retard pad need replaced. They are simply worn.
SOURCE: automatic document feeder not working
Open the adf and rotate the pick assembly till you hear a click and then take a coin and run it up and down against the separator pad and then see if the adf picks the paper or not.If this does not work try this *# 329 and scroll thru and select adf pick test if that fails its time for you to get the printer replaced or get an upgraded printer
SOURCE: HP Officejet Pro 8500 has problem with document
Follow this steps to make it work..
SOLUTION #1 CLEAN THE ADF FEEDER
1. take out all the papers that you have on the printer
2. turn off () the printer using the power button
3. unplug/disconnect the power cable at the back of the printer
4. Lift the cover of the ADF, and then find the rollers and the separator pad.
what is separator pad?? click here
5. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth.
6. Use the damp cloth to wipe any residue off of the rollers and the separator pad.
7. Dry the rollers and separator pad with a dry, clean, lint-free cloth.
8. Close the cover of the ADF.
9. Reconnect the power cord to the rear of the product.
10. Press the Power button ( ) to turn on the product.
11. Reload the original document print side up in the document feeder tray.
12. Try to make a to make a copy again using the ADF, if you are still having issues with it, continue to the next step.
SOLUTION #2 RESET THE PRINTER
1. turn off the printer ()
2. unplug/disconnect the power cable at the back of the printer
3. while the printer is off and unplug, on the control panel of the printer press the # and number 3 at same time (keep on pressing and wait for 1min)
4. after 1min. keep on pressing the two buttons then plug the power cable back in to the printer.
5. If the printer does not turn on, press the Power button ( ) to turn it on.
6. release the buttons when part NVM reset appears on the printer screen.
7. press ok, then continue the following task.
IF THIS STEPS DID NOT RESOLVED THE PROBLEM CONTACT HP PRINTERS SUPPORT DEPARTMENT
1-800-474-6836
Good luck! :)
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
