For E6 and E7 codes, while this code is displayed:
First, press and hold Level Minus, then the Start key (the Level Minus key first), for 2 seconds. (make sure you press Level Down a little before Start.) The console should beep twice; the display does not change.
If the potentiometer value on the left of the screen is higher than 240, press and hold the Ramp minus key to lower the ramp until the value is in a range between 48 and 240. Then release the button. May reset by itself now. Or, turn the elliptical off and back on to reset. If ramp goes up to 255 and won't move in any mode, unplug power for 20 minutes.
If the potentiometer value is lower than 48, press and hold the Ramp plus button to raise the incline until the value is in a range between 48 and 240. Then release the button. May reset by itself now. Or, turn the elliptical off and back on to reset.
Now press Start, and pedal for 30 seconds. The ramp should reset to zero, the lowest level.
Https://www.lifespanfitness.com/fitness/resources/articles/what-does-your-treadmills-error-code-mean
Quoting from link above: "An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
Also note that not all models will have the ability to adjust the incline motor. If the adjustment procedure is not found in the Owner's Manual then contact customer service."
This info is in the manual but there are not instructions on how to "Get into test mode and enter through the I/O testing step." Any suggestions how to do this?
I have the same problem! NOWHERE ON THE INTERNET does it say how to enter test mode for a Lifespan E3i Elliptical. Lifespan tech support is the same thing. All the detailed steps to fix the problem are there once you're in test mode, but WE NEED TO KNOW HOW TO ENTER TEST MODE. It is different for every elliptical. Ive tried the methods for other models I've found, and guessed 100 button combo's, but can't get into test mode. Please help.
SOURCE: i need a users manual for a bh fitness ocean program elliptical
go to www.fitness.manualsonline.com or www.iconservice.com
God bless you
SOURCE: what does E7 mean on Lifespan TR4000i?
see the 2 alternatives that the error code 7 means: E7-
1) Alternative Elevation Motor 1)Cause:
Elevation Motor not moving Solution:Check
Elevation Motor connection 2)Cause:
Elevation Elevation Motor screw binding Solution:
Clean screw and lubricate 3)Cause:
Elevation Motor Motor out of Range Solution:
Check motor out of elevation 4)Cause:
E-Motor Potentiometer: Solution:
Replace Elevation Motor 2)Alternative: Display
Doesn't Light Up: a)Cause:
On/Off switch Solution:
Test unit is turned on b)Cause:
Insufficient Power Source Solution:
Plug
dedicated120V, 20Amp Outlet c)
Cause: Line
Cord Damaged Solution:
Replace Line Cord d)Cause:
Fuse Solution:
Check Fuse on MCB
However RUN the software calibration for diagnostic, troubleshooting and Fix it.
God bless you
ERROR
CODE # 7
E7-
1)Cause:
2)Cause:
3)Cause:
4)Cause:
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
Plug
c)
Cause:
Line
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
E7-
1)Cause:
2)Cause:
3)Cause:
4)Cause:
2)Alternative:
Display
Plug
c)
Cause: Line
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
God bless you
