SOURCE: fridge not cold freezer ok
More then likely your problem is that its not defrosting correctly in the freezer and the ice has built up behind the panel and not allowing the cold air down into your refrigerator.
SOURCE: Westinghouse Virtuoso Fridge - Circuit Diagram
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
SOURCE: westinghouse virtuoso fridge door wont shut. it is
SPACER WASHER ON PIN HINGE GON AWOL/REPLACE IT..if can lay unit over to get to screws on bottom hinge of unit underside, awkward/heavy, not on your own please ,this mother is heavy.........
SOURCE: Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
SOURCE: westinghouse virtuoso fridge freezer manual
where is filter located for water and ice block dispencer on a 2003 model
