SOURCE: maytag neptune washer
yes, but 900 is a little high for my area. is it loud in spin now? the seal can be replaced for about 50-80 part labor is 1 to 3 hours. if you just smelled the smoke and it is not loud you are ok for a long time, reduce load size and it will probly be ok for some time
SOURCE: I just bought a house
SOURCE: My older Kenmore washing machine isn't draining
when you close the lid can you hear a click from the switch?if not replace lid switch
Testimonial: "Perfect! And such a simple solution. To think I was just going to buy a new washer when all I needed to do was fix a little lid switch. Thank you!!!"
SOURCE: Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
Do you know what the amp rating was for the momentary on switch that you originally used?
