LR22132, 5hp,3450rpm, 60hz,XM56FR, KVA code- D, Type-T,230volt, 15amp Doeer motor. Capacitor went out, do you have a part number for the replacement capacitor?
    Guru:
  • 606 Answers
Most of the time the capacitor is listed on the motor, if not it should be on the capacitor itself. If it's enclosed you may have to remove the cover to find it,
Posted on Feb 19, 2019
Testimonial: "The capacitor was there, however, the issue is that the housing around the capacitor rubbed off all the identifying info on the capacitor so I have no way of knowing the specs. Its a "Murphy's Law" type of thing here."
  • Bill Long Feb 20, 2019
    Can you read the model number and serial number on the motor nameplate. If you can most of your motor rewind and rebuild companies in your town can help you get the right capacitor
6ya staff
SOURCE:
Anonymous
  • 254 Answers
SOURCE: HELP!!! Help wiring new motor for CKL60-1
  1. This is what your wiring should look like if you are using two caps. then you should be using a potential relay as well. This is the diagram for using a potential relay. Hope it helps you.
Posted on Aug 28, 2008
Anonymous
  • 261 Answers
SOURCE: GE Washing Machine Replacement Motor - Capacitor? Relay? Schematic?
The new units have all of your schematics, capacitor and a higher price for a reason. With GE I avoid used parts because there is so much electronics you don't want to fry. The wire harness leads match the old and there should not be an extra wire, were would it go if there is not a receptacle for it?
I looked up your unit and the motor replacement is WH20X10009 for the model you quoted. As of now GE is has updated this to model wh20x10006 for around 263 dollars.
Posted on Oct 03, 2008
Anonymous
  • 400 Answers
SOURCE: Dometic Duo-Therm - 13,500 B.T.U. Model #3107541.009 - Serial # WA346967 - Yr. 1999-2000. Blower motor will not start. Replaced the start capacitor - no help. It will run by spinning the motor by hand
Yes you should try replacing the run capacitor.
Posted on May 08, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: WHAT TYPE OF REPLACEMENT CAPACITOR DO YOU USE FOR
If you are working in the switching power supply and need electrolytic, I would use PANASONIC FM series for very low ESR, High ripple current rating, 105c temp. Get them from www.digikey.com
Posted on Nov 18, 2009
Keith Fournier
  • 308 Answers
SOURCE: wiring diagram for electricmotor with capacitor
I do not have a diagram for you, but depending on the motor, I can tell you a couple of things. 1. All capacitors are wired in series with the start winding. Most multi-speed motors, that require capacitors, have two brown leads, along with the motor winding leads. If this is the scenario, then just connect line power to neutral and the speed you wish to use, and connect the two brown leads, one to each side of the capacitor. Hope this helps.
Posted on Apr 01, 2010
Testimonial: "Thankyou for your assistance,very helpful."
Can i use a 50hz 220V SPLIT TYPE AIRCON TO 60HZ 220V
you probably can but it will be damaged over time, you would need to replace the motor inside to handle 60hz using the 50hz can do damage to the motor, or even cause a fire. also if it has a power capacitor that asys 50hz on the power line to the unit inside this would been changing as well.
Jun 29, 2017 | Heating & Cooling
I have a 3/4 horse 115-203-230volt motor everything is hooked up correctly according to the specs but it will run for a few real good and shut off what can be the issue
Is the motor thermal overload tripping? This usually happens when the start capacitor does not switch in when the motor starts. Look at the centrifugal switch in the back of the motor under the cover. If all is well, then the start capacitor may need replacing.
Sep 26, 2015 | Cars & Trucks
Trying to get info on both capacitors.GE motor 115volt 3450rpm part# MO 9045
the rating for the capacitors is printed /imprinted on the capacitors
take them along with the information you have given to a electrical motor rewind shop and they will match them up
Apr 19, 2015 | DeVilbiss Air Tools & Compressors
What capacitors do i need to get to replace the ones on a 6 hp motor
Due to the nature of power factor correction and other sizing criteria it is best to open the can on the motor that protects the capacitor and order a comparable unit for capacitance, number of sections (- ie, start/run versus Start or Run) plus capacity and working volts AC. Unless ordering from the original compressor supply company, most parts houses will not have a cross reference with that data.
Jan 31, 2012 | AO Smith 6 Hp 3450rpm R56Y Frame 230 Volts...
Need to replace a Diehl Typ 880, T85 120V 60Hz 15Amp timer what is its current model to replace?
The Type 880 is the exact replacement. Still available at most pool supply outlets.
Sep 27, 2010 | Hardware & Accessories
Can I plug in a 230V 15 amp window air into my 20 amp wall outlet or is the 20 amp wall outlet not giving me enough volts. if not then how can I do this without wiring up a new circuit/outlet?
Hi, the amps would be OK, but you have to have a 230 volt outlet to plug it into, or it will not run. There is no other way to do this unless you run a 230 volt line over to the window unit. You can do this from the outside of the house. This is all you can do unless you move the a/c to where you have a 230 volt plug, and I don't think you want that. This is the only way I am sorry to say.
Sincerely,
Shastalaker7
Jun 12, 2010 | Maytag M6W12W7A Air Conditioner
Need to convert my 110 volt 15amp to 240 volt
You can buy a transformer which allows all 110v power tools to work from a 240v supply. You will also need to change the plug on the compressor to a yellow 110v type. You can buy transformers for around £25 and around £3 for the plug
Mar 29, 2009 | Craftsman Air Tools & Compressors
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
