Health & Beauty Logo
Shelia calvert Posted on Feb 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a wolff scs usa wss24 1983does it have a body ground it shicks me wen i touch the top and bottom at the same time?
medypharma2148
Level 2:
Sergeant:
New Friend:
  • Wolff Expert 176 Answers
  • Posted on Feb 18, 2019
medypharma2148
Wolff Expert
Level 2:
Sergeant:
New Friend:
Answers
176
Questions
0
Helped
103897
Points
707
Buy Dacilon 0.5mg injection Online is an anti-cancer medication. It works by damaging the genetic material (DNA) of the cancer cells and stops their growth and multiplication. Cheap Dacilon 0.5mg injection From Trusted Pharmacy Medypharma.
1 Related Answer
Anonymous
  • 97 Answers
  • Posted on Aug 21, 2010
SOURCE: hi sir.
Try to manually recalibrate the touch screen. Click on start -> Settings -> System -> Touch Screen and follow the prompts.
Diagnostic connector location
USA? what country?
RHD or LHD (right or left hand drive)?????
all usa cars, the 16pin DLC is less than 1meter from the steering wheel.
yours is behind the ash try(pull it)
some old honda's here, usa have dual ways to get scan codes.
the obd2 way , and obd1 way, RTM
read the FSM. or google for that.
I use ,alldata.com for fast answers, saving google searches and bad answers on forums...
fsm quote.
The 16-pin On Board Diagnostic version II (OBD-II) compliant Data Link Connector (DLC) is used to access the Diagnostic Trouble Codes (DTCs) using an OBD-II compliant Data Scan Tool (DST). It is an electrical connector with a gray housing located under the dash, either near the center console, on the passenger side of the vehicle or to the left of the driver side of the vehicle.
The two wire electrical connector with a blue housing next to the DLC is the Service Check Connector (SCS).
we (uSA have 2 DLCs. one is OBD2 and other is SCS.
id use a real scan tool. and not fool with the old winky blinky bs.
the scan tool you can check all live sensor data.
do that. and win.
1st goggle hit on SCS
http://honda-tech.com/showthread.php?t=2703528
How to remove and install ballast in sunquest 24 taining bed
I have a question for someone who knows about a Sunquest 24 r tanning bed? Involving bottom bulbs not lighting at all?
1helpful
BALLAST FOR PRO 24
A trained technician should: Turn off power to bed. Remove top or bottom cover as necessary, Locate bad ballast, Insert small insulated screwdriver into slot on end of ballast and pull out wire, Remove one screw that holds ballast in place and loosen the other screw, The end of the Ballast should be slotted - so pull it out from loosened screw. Now reverse the process to install new ballast. After remounting ballast to bed, simply push the wires back into small holes in connector.
Sunquest 24s wont do nothing
Have a trained technician to check for blown fuse on back of bed and then for burned out wiring in top and/or bottom of bed. Voltage going to bed may also be a cause. These beds are sensitive to wrong voltages.
2helpful
Wolff sunquest bottom lights dont turn on
There should be a cord that goes from the top of bed to the bottom section of the bed in the back of the bed. Make sure the cord is plugged in all the way and is not broken. This cord could be bad, the plugs may be bad, the cord could be missing entirely. A connection to the plugs could be burned out inside the top or bottom sections or at the main power relay.
1helpful
My amp wont turn on
try this it may help
the amp body may need to be grounded in addition,
try screwing it to contact a metal surface or run the ground wire to the amp body and then loop it to ground terminal have fun
SHARP WIZARD OZ-590A DATA ORGANIZER
Turn on your organizer and touch the Clock Icon with your stylus. Just to the right of the bold heading on the top of the screen is a downward arrow. Touch the arrow with your stylus and a screen should come up with with six different modes of your choice. Touch the Home clock. Now touch the Edit on the bottom right hand corner of the screen. Touch the left solid arrow on the bottom of the screen enough times to bring you to the Country at the top of the screen. Touch the solid up or down arrow until you come the USA. Touch the solid right arrow unil you see the USA city field. Now touch the solid down arrow until you come to your city. Touch the solid right arrow once and the hour should be highlighted. Enter your hour. Now touch the right arrow to enter the minutes. Continue with the right arrow to fill in all the values and touch am or pm. Finally touch save or enter. The little smilly face is for daylight saving time which is touched on in the summer time. Hope this helps you, [email protected]
Top Wolff Health & Beauty Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Wolff Health and Beauty Expert? Answer questions, earn points and help others
