Husqvarna Viking Designer II
The Designer II should not be oiled by the user. As with most computerized sewing machines, it's got a sealed bearing system. You do need to clean the bobbin area and the space under the bobbin case. See page 65 of the user manual to open stitch plate to clean the bobbin area and feed dogs. Next remove bobbin case holder and bobbin case to clean under there. Sometimes the interdental brushes can get some of the lint that the sewing machine brush misses.
The manual for the Husqvarna Viking Designer II is available on the product page: http://www.husqvarnaviking.com/en-US/Machines/DESIGNER-II . The current link to the manual is http://www.husqvarnaviking.com/getattachment/Machines/DESIGNER-II/Designer-II.pdf.aspx .
I hope this helps.
SOURCE: I need the driver installation for my reader/writer d-card
Drivers are on the installation disk. 3D will have it on cd#1 and 4D on the dvd. With the disk in the drive, plug the dCard reader/writer in and use the "add new hardware" wizard to allow the drivers to install automatically. Now,either repeat this for each usb port or remember to always plug in to the same port.
SOURCE: husqvarna sewing machine - viking 400
Take to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner. Check Husqvarna Viking website for dealer closest too you.
SOURCE: Need Viking Husqvarna Designer 1 ESS Owner's Manual
Try ebay or contact your local authorized Husqvarna Viking dealer. You can find a dealer closest to you at the Husqvarna Viking website - http://www.husqvarnaviking.com/us/
SOURCE: I have a Husqvarna Viking quilt 870 sewing
The overload message is usuall due to a bind in the mechanical function of the machine. When the motor has an extra "load" caused by something like a tight belt or dry bearing, it "overloads" the motor and the error message is displayed. It is doubtful your problem is computer related. Either way a trip to your service tech is required. If you continue to sew with it, you do run the risk of possible damage to some other parts of your machine. The computer portion of your Husqvarna is guaranteed for 5 years and the mechanical parts carry a 20 or 25 year guarantee depending on when you purchased your machine. A copy of your bill of sale from a Husqvarna Viking dealer or a stamped warranty card is the proof of purchase needed to obtain warranty replacement of parts. Labor is only guaranteed for 1 year.
SOURCE: Husqvarna Viking Designer I breaking needles
Dls8864's suggestion was a very good suggestion - make sure the metal stitch plate is pushed all the way to the back. Also make sure that the thread is feeding freely - if it is catching on something it can cause the needle to be pulled aside and make it break. Does the design fit properly inside the hoop you are using? If the foot and/or needle strike against the side of the hoop, that will cause a breakage. Is the bobbin thread okay - not making a bird's nest underneath?
