Question about Boss Music
Boss me 70 skeep phrase loop.the knobe show 9 instead of 10 , and the loop don't work .
My Boss ME-70 han only two dots when i power on ,pedals dont lit when i press it down, is there a solution with this?
PDF]BOSS ME-70 Training Guide - Roland
cdn.roland.com/assets/media/pdf/ME-70_Training_Guide.pdf
AC adaptor. • $418.50 List, $299 MAP ... Connect the ME-70 to power using a BOSSPSA-120S AC Adaptor. 4. Plug a guitar into the ... For illustration only ). 4. Press the ...1. Turn the MODULATION TYPE knob to select a Modulation effect. Do not ... 2. Pressboth pedals down again or press EXIT to return to Manual Mode.Missing: han ‎dots
ME-25 Guitar Multiple Effects Review ' Boss ' Guitar Effects ...
https://www.ultimate-guitar.com/.../boss/me-25_...
Ultimate Guitar Archive
Rating: 8.6/10 - ‎135 votes
Sep 16, 2015 - Overall the effects are very very full sounding and don't sound too digital by any means. ... With 2 selector pedals, up and down, its a pain in the ? ... Editing the patch is as simple as press 2 buttons at the same time and turning ... If this was stolen I would probably get the ME-70 just because it pretty much ...
Tom Scholz's Guitar Sound - Van Halen Links.com
Jan 06, 2016 | Roland Boss ME-70 Guitar Multiple Effects...
Contact boss
BOSS ME70 Factory Reset.
Just do this:
Jun 11, 2014 | Boss ME-70 Guitar Multiple Effects Pedal
I have the Roland Boss Rc-20xl Loop Station, and I'm running off of batteries I have been since I got the pedal. In the middle of recording a phrase the pedal shut off and started resetting itself...
Hello!
I am not positive on this but I would try to clear all of the loops. Try holding the right pedal for about 5 seconds.
If that does not work, hold the right pedal for about seconds while you turn off the unit. Release the right pedal then turn the unit back on.
Hope that helps!
May 11, 2011 | Roland Boss RC20XL Phrase Recorder Pedal
Im trying to connect two rc-50 via midi! I want one of the them to act as a master and the other one as a slave. The goal is to have both machines working independently but have all loops on each rc-50 to...
While you can probably get the functions sent by MIDI to transfer to the other unit, syncing PROBABLY isn't going to work very well because there is a lag to form the MIDI sync clock (serial data) and then receive it, decode it and do something with it.The transmit time is about 1/3000 of a second and receiving is at least that much time. On rhythm things I have found the ear can hear 1/1000 of a second easily. If one could set the machines to use an EXTERNAL sync clock and drive the SAME clock to both units, you might be able to sync them together time wise as they would see the sync at identical times.
Apr 14, 2011 | Boss Rc 50
When I turn on my BOSS RC-20XL Loop Station the reverse, tap tempo, write, exit and one shot phase start to blink rapidly and I cannot get them back to normal. Therefore, I am unable to use my loop...
Hi. I had the same problem and fixed it by clearing all the phrases. An explanation of how to do this is below (written by someone else, not me) But, expect your guide beat to now sound like a fuzz instead of a drum. This really sucks and there is apparantly no fix for the guide sound except to send it back to Boss. Good luck.
1. Start by selecting Phrase 1.
(if the 'REVERSE' or 'AUTO START' are lit press them off.)
2. Select 'INST & MIC' by pressing 'MODE'
3. Hold down 'EXIT' and 'AUTO START' together - at the same time, this should light up the green LED for 'LOOP PHASE'
4. Hold down 'WRITE' and 'EXIT' together
then hold 'WRITE' on its own
then 'WRITE' and 'EXIT' together again...as if you were clearing a phrase.
they should light up in red and flash, if not try a combo of section 4.
5. Repeat on all Phrases 1 - 11.
Mar 24, 2011 | Roland BOSS RC-20XL Loop Station Phrase...
I have the Boss RC-50 Loopstation. It has been great. Perfect operation for about 8 months. Today, when I started to use it, I noticed that I couldn't select "Phrase 1" by tapping the pedal....
Likely the switch contacts for that pedal have failed. You will probably have to get it repaired. Stomping on the pedals is a good way to damage them, but the switches are often marginally designed anyway...
If you can access the switch you could try getting some CRC226 available at Home Depot in the electrical department into the switch, but often the internal parts of switches fail.
Jan 30, 2011 | Boss Rc 50
I connected an RC20 to a 16 volt/800milli supply & blew it.
It would be helpful if you told us what type supply you connected to the unit.
These normally run off a 9 volt DC supply. Likely you wiped out the input regulator chip and maybe a diode and capacitor.
It is definetly worth repairing.
If you open it up the damaged parts MAY be obvious. There may be a couple which do not show the damage.
Apr 20, 2010 | Boss Rc 50
Beggining of loop missing on FIRST playback only, on Boss RC-50.
Ok, solved this problem by visiting roland U.S. site as the help offered in this country is useless. The instructions given by email would not have worked even after the update was installed. Luckily, there are instructions that come with the download. If you have same problem as me go to http://www.rolandus.com/products/productdetails.php?ProductId=772&tab=downloads&skip=true
and update the opperating system on the RC-50 to RC-50 System Update Version 1.01.
Then hold loop sync and phrase 2 button (think it was phrase 2) to change it to sound priority mode. Then it will play back correctly what you recorded on the first loop, rather than missing the first beat.
Am v.happy I have found this, as after much searching I can't find any other loopers out there that offer 3 seperate loop tracks and the ability to switch between them effectively. Plus, it's a very convenient size, better than a load of rackmounted stuff to haul around.
However.....
Another problem..
When hitting the reverse switch ( I assigned both external footswitch and the onboard Tempo pedal to reverse) the change is not instanteaneous. There is a second or so delay before it plays in reverse. Not a problem for most, I suppose, but I have a piece that switches rythmicaly between playing forward and reverse which means hitting a pedal in time and reverse/forwards changing immediately. I think they could do with another software update to solve this. Now I have to keep room in my enormous pedal board for the old rc-20, as that does the reverse as it should - when you hit the flippin switch!
Jun 19, 2009 | Boss Rc 50
Music Logo
93 people viewed this question
Top Boss Music Experts
Michial Gueffroy
Mosaub Al Masri
Mosaub Al Masri
rhodesworks
Are you a Boss Music Expert? Answer questions, earn points and help others
