SOURCE: Whirlpool model LSR7233EZO / doesn't fill fully
The fill switch is a very sensitive device. You can test it by blowing into the tube, listen for the switch to click, or use an ohms tester. They are actually adjustble, the adjuster screw usually has glyptol (thread lock) on it. I would replace one before trusting an adjusted one.
SOURCE: Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
SOURCE: Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
SOURCE: I have a Maytag stackable
Hello &
Welcome to FixYa Please check
this picture....part#11 is the water level switch that controls the water level
through the valve. Please get back to me if you have any other questions. Kevin
