SOURCE: sony boombox model cfs-b11 transformer
Your tape requires 9 volt transformer as shown in below schematic..
Part number is 1-450-016-11
SOURCE: need to know the power supply req for a beyond micro bmmdu2 power supply
It should be a 12v 1.5 amp switching supply
SOURCE: our sony 830 g will shutdown and restart on its
Trace the wires from the power supply to the points where they connect on the board and the feed to any components. As you do this look for loose connections or cables that are not properly seated. To be safe, in plug the wire or cable contact and plug it right back in, making it is firmly connected.
I have fixed several issues with the VAIO doing just this when support had no answer.
Should you see and wire that has been pinched or crimped it may need replacing.
SOURCE: i have intel board DG41RQ
In my opinion Motherboard issue, but I can't assure, it could also be the Power supply, as bad power supply could cause the motherboard mal-function and is causing the hard drive failure. If the motherboard is under warranty, you better get a replacement than wasting another Hard drive, and I hope it's better for you to replace the power supply as well, you'll spend less buying a 450watt power supply than buying a new 500gb hard disk.
Also make sure the cabinet is properly fitted and the ground is working without any problem, you can check this by using a tester (screw driver tester) after it's connected to the mains, or you can try with your hand (it'll not kill you :-], but I don't recommend if you have a screwdriver with tester).
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
SOURCE: I have a Sony cfs-w360 boombox that needs a power
LOL!!!!I was just cleaning out my storage and stumbled across my old CFS 360W! with the detachable power cord. Was trying to see what its worth. But yes, I have one. I can be reached at [email protected]
