B
BIGGY GARIMOTO Posted on Feb 12, 2019
HOW TO FIX PAPER JAM ON KYOCERA ECOSYS FS-1135 MFP PRINTER
Harris
Level 1:
New Friend:
  • Contributor 82 Answers
  • Posted on Jun 16, 2019
Harris
Contributor
Level 1:
New Friend:
Answers
82
Questions
Helped
85588
Points
97
First you have to find out where the paper jam occurs. Check the Rollers and the clutches, then the sensor for the registration and finally the exit sensor. Clean or replace any defective part.
5 Related Answers
Anonymous
  • 25 Answers
  • Posted on Dec 31, 2008
SOURCE: problem with EcoSys Kyocera FS2000D
that is a fuser code check the fuse
Anonymous
  • 2120 Answers
  • Posted on Jan 23, 2009
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
don_farr
Don Farrell
  • 1018 Answers
  • Posted on Nov 19, 2009
SOURCE: how do i print envelopes on a kyocera ecosys FS-1300d
Just a suggestion but in the application you are using, make sure the "Page Setup" is set to the envelope you need and the source for the envelope is correct.
Also, check the driver settings to make sure they match what the application needs.
Don
Anonymous
  • 241 Answers
  • Posted on Jun 09, 2010
SOURCE: Kyocera FS-3900DN Ecosys Call Service 2200:0100998
The Call Service 2200 is a drum motor error. The motor or gears might need to be replaced. First remove and re-seat both the developer and the drum unit. The developer is directly under the toner cartridge - lift it up then out first, then open left side door remove the waste bin and press the button on the drum unit just above the waste bin pull the unit out (carefull not to touch the drum surface). Re-seat both units. If this does not work call in a Kyocera Tech.
caroldon
  • 17130 Answers
  • Posted on Sep 26, 2011
SOURCE: KYOCERA ECOSYS FS-C5100 DN PRINTER. WHEN I TURN IT
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
1helpful
Kyocera ECOSYS FS-6525MFP. Error 4209
Question edited for clarity.
This is not a fuser unit error. Why change the fuser? Was it jamming at the fuser? Change paper to a better quality and make sure it is dry. A sensor is sensing a paper jam because the paper hasn't exited the machine.
4209 - The eject sensor (ES) does not turn on during paper feed from MP tray.
https://www.eps-antennas.de/fs-6030-mfp/fs-6025mfp_6025mfp-b_6030mfp_sm_rev_1.pdf
Generic Kyocera 4209 Error and fixes.
https://www.google.com/search?q=Kyocera+Error+4209
Can you use a Kyocera FK-170U fuser unit in place of a FK-150 fuser unit?
No the FK-170U fuser will not work in a printer that is compatible with the FK-150 fuser unit. I found a Kyocera FK-150 Fuser Unit available on Amazon here: https://www.amazon.com/Genuine-Kyocera-FK-150-302H493032-Kyocera/dp/B00GOO57M2 . Other sites have third-party replacements.
The FK-150 fuser is the correct fuser for the FS-1028MFP, FS-1128MFP, FS1350DN, among others. The FK-170U fits the following Kyocera printers: FS-1035 Mfp, FS-1135 Mfp, FS-1370DN and FS-1120D. There are a few other printers. The design changes means they can't be substituted.
I hope this helps.
How do I clear the memory on a ECosys FS-C2126 Copy/printer
it is under mode 21, you need to login first to maintenance mode by punching the numbers 1087 1087. then select the number 21 then hit start. you will be able to clear the memory .
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
How do i clear jam 20 in fs 3140
You can find it on page 375 of the user manual here: http://www.manualslib.com/manual/450403/Kyocera-Ecosys-Fs-3140mfp.html?page=375
just continue with page 376, 377, 378 to follow the instructions ...
Why i cannot send a fax from my kyocera ecosys fs-1135 mfp?
If you can receive but not send, maybe the number you are sending to should include some pauses, especially at the end of the number. If you have a good dial-tone when you do "On-Hook" then there is nothing preventing you from sending on the machine end. Has the phone system just gone digital? You may need a filter to translate pulses properly. Can you call your cell-phone using On-Hook dialing? I would say there's nothing wrong with the machine. But you'll get blamed for the communication problem in any case. Try manually dialing using On-Hook dialing (turn your Monitor sound up high) and listen for some kind of message. It's a number or line problem. Did they just start requiring an 8 or 9 to be prefix-dialed to get "out?" Or stop requiring it? Maybe there is a prefix number programmed through the default menus that you don't need anymore.
Copystar Kyocera FS-1135 MFP waste toner full
I can not find the screw razor is talking about.
11helpful
2answers
Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
1helpful
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
