Buy Zecyte 250 mg Online is contains a medicine called Abiraterone Acetate. Zecyte 250 mg manufactured by Cipla Inc. Buy generic drugs from this Trusted online pharmacy Medypharma, get great discounts and Free home delivery on Order above $249!"
Free manual for a different model that might be helpful:
http://www.scalemanuals.com/taylormanuals/5758-manual.pdf
SOURCE: body fat scale Question
Like all body fat tests, body fat scales don't actually measure your body fat percentage. They determine your body density. The examiner (or the scales) then uses a formula to calculate body fat percentage based on body density. These formulas just predict your body fat. Unfortunately there is no one formula that accurately predicts body fat for the whole population. Differences in age, gender, ethnicity, body size, and fitness level all have a significant affect on the results. Well, whether body fat scales measure your "true" body fat percentage or not doesn't matter! As long as they can accurately monitor changes in your body composition over time, that's all you need.
SOURCE: Taylor Scale 7532s - not working
This link allows you to trouble shoot directly with the company....I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
SOURCE: We have a Taylor 7542 Bathroom Scale. I need to
I called Taylor; the Model 7542 take a 3v CR2032 battery available at Walgreen's, CVS, WalMart, etc.
SOURCE: I have a Taylor body fat analyzer and scale model
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
I got an ERR2 message and now the scale doesn’t work. What should I do?
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
SOURCE: how do i program the taylor body fat scale
From the Taylor web site
The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
Testimonial: "The website does not have a manual. Using 'search' or site map produces nothing. Another problem: scale reads only in cm and kg. Won't cycle to ft/lb."
