I'm sorry that the Camera
is displaying the error message. "TURN THE POWER OFF AND ON AGAIN"
displays on the LCD screen when the Lens Mechanism is stuck or when affected by
any malfunction. If turning the power on and off again does not resolve the
error message, try doing a power reset. Please follow the below steps to
perform a power reset.
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
Also tryinitializing the Cameraif
you're able to access the Menu items on the Camera. The Initialize option will
be available under Setup or Main settingsSub
Menus.
If the issue persists again, service is required.
Please click hear to locate
the service center near your area.
Thanks for understanding. Please let me know if
your require any clarifications.
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
?· Turn off the camera.
?· Remove the battery pack.
?· Press and hold the power button for 30 seconds.
?· Allow the camera to remain without power for 60 seconds.
?· Reinsert the battery pack.
?· Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks,
KenSolutions
FixYa
