SOURCE: Stihl FS 110 brush cutter loop trimmer
Check the fuel filter, you are not getting fuel so therefore the spark is not getting anything. You can also take some carb cleaner and clean your carb. This is a common carb issue and it needs either a new filter(recommend) and also some carb cleaner shot through the system
SOURCE: STIHL FS110R weedeater won't start, does not hit
my son flooded out my stihl weedeater, I took it had a new filter put in and it started right up. he went to use it again and now it wont start! It sat overnight and i still can start it! Any suggestions please
SOURCE: my stihl weed eater will start but not rev up
little cable with toggle on the end of it, this has come off the carb
SOURCE: weed eater bogs down
Under what conditions does it bog down? When it just idles? Cold or hot? When you give it gas? When you try to cut?
SOURCE: stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
