Possibly a malfunction of the micro processor or even a power supply hard to tell.Good luck
Hi John, for what your Teac says, you are not completing the start sequence, I suggest you disconnect the Teac, for more than half an hour and after that time connect it and see if it turns on
another possibility is that you need a Firmware update
The Firmware can be updated through the USB port. Once you have downloaded the firmware
from www.teac.com.au, place it on a USB stick. Please make sure that the USB memory does not have
other files stored on it other than the required software file
With the Teac HDR9650TS DV Recorder, unplugged, place the USB memory into the USB connector, then turn on the computer and wait for the power-up sequence to complete
I send you the link to download the service manual
I hope he manages to solve the problem
Greetings Franco Dosil
Hola John, por lo que comenta su Teac, no esta completando la secuencia de inicio, le sugiero desconectar el Teac, por mas de media hora y transcurrido ese tiempo re conectarlo y ver si enciende
otra posibilidad es que necesite una actualizaci?n del Firmware
El Firmware se puede actualizar a trav?s del puerto USB. Una vez que hayas descargado el firmware
desde www.teac.com.au, col?quelo en una memoria USB. Por favor, aseg?rese de que la memoria USB no tiene
otros archivos almacenados en ?l que no sea el archivo de software requerido
Con el Teac HDR9650TS DV Recorder, desenchufado, coloque la memoria USB en el conector USB, luego prenda el equipo y espere que se complete la secuencia de encendido
Le env?o el link para que descargue el manual de servicio
Espero que logre resolver el problema
Saludos Franco Dosil
https://www.manualslib.com/manual/764925/Teac-Hdr9650ts.html
SOURCE: unlock region codes for teac dvd player, model dv-4180
Hi Pacificmarli
I found the following Multizone Instructions for Teac DV-4180:
Hope this helps.
Miche
I have 2 of these units & both ended up having the same issue. In both cases it was the same capacitor on one of the boards. Look for a bulging end on the capacitors - that will indicate they are stuffed. I just desoldered the capacitor from the board, checked the number on the side of the capacitor & went to EBay. I bought 20 capacitors on Ebay for $5.00.
Cheap Fix.
