SOURCE: Recessed handle is stuck in closed position
I would likely try WD-40 and gentle maneuvering.
How long has it been since it work and you've tried it again?
SOURCE: Sharp R1514 - handle is stuck "in"
The mechanism has failed. simply replacing this handle(push) mech will fix this issue.
SOURCE: handle wont go to upright position
The red pedal has slipped out of position. On both ends of the red pedal you'll see metal rods (the axel of the pedal). On one side you'll see the metal rod sits into a long groove, on the other side you'll see the metal rod sits into a round hole. They both have to be in the long grooves so you have to reposition the rod that's into the round hole by pulling it out and sliding it back into the long groove above the round hole. You'll now be able to bring the handle up and lock the machine back into the upright position.
SOURCE: replace parking brake handle
Same problem - the stupid thing just snapped off in my hand! Any idea how to install the replacement part? Am NOT going to the dealer unless I absolutely have to. Thanks!
SOURCE: dyson 28 handle is stuck in the locked and upright
how do you remove the air duct (plastic sliding piece) that is making the vacuum stay in locked upright p[position?
Same problem I had with the pivot yoke phoned Gtech got replacement pivot yoke
