Pool & Spa Logo
Kellie Galati Posted on Feb 05, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to access waterco 25 A chlorinator manual
Kardoc
Level 3:
Top Expert:
  • Waterco Master 7,503 Answers
  • Posted on Feb 26, 2019
Kardoc
Waterco Master
Level 3:
Top Expert:
Answers
7503
Questions
0
Helped
2757082
Points
58323
2answers
My Waterco Titanium Instamatik 90 display shows 34 degrees and won't start I don't know why ? The fan doesn't spin?
Post edited for clarity. Post moved from Cars to Pool and Spa.
Contact the maker direct.
Pool and Spa Spare Parts - Waterco
https://www.waterco.ca > ... > Spare Parts > Pool & Spa
Downloads. Catalogs · Brochures · Manuals · Spare Parts · Pool & Spa · Water Treatment · Aquaculture. Pool & Spa - Spare Parts. Blowers.
Jun 21, 2021 • Pool & Spa
Hi there, I have a waterco hydrochlor 25 sc that appears to have suddenly stopped working. I was hoping for some advise to narrow down the problem.... Check a fuse, etc. Could someone assist?
if this is a salt brine water chlorinator id say if membranes in brine tank are over two seasons old this needs to be replaced , this can be confirmed by gathering samples from both A/B sides of membrane and taking to a water quality lab for testing for a lab report of % cloride in differance to both sides if results are low then membrane is defective
Oct 06, 2014 • Pool & Spa
Water is clear but chlorine and copper still low, what I need to do?
The salt generator only works when the pool pump is running. If you want a higher chlorine level, run the pump longer. Also, to keep your chlorine in the pool, be sure to adjust the stabilizer level. (25 ppm for salt systems). As for copper, this level should be 0 at all times
Fan Runs But Compressor Does Not kick In Waterco Aqua Heat Titane 101
I had the same problem last week. I called a technician who found out that the capacitor was defective. Cost 50$ + the service call.
If the capacitor is working, it might be the compressor...
9helpful
How do I replace the sand in my waterco t400 pool pump. Is there a manual available
Replacement of the sand is easy but there are a couple of things you want to do first.
Make sure you have a good shop-vac, get gloves, and purchase the proper sand.
This sand filter calls for #20 silica filter sand. (this will be available online, at your pool store, or at any water treatment facility).
Here is the link for this filters manual, and for the brochure (which has good pictures)
http://www.waterco.com.au/CMS/uploads/brochures/ZZB0512_Thermoplastic.pdf
http://www.waterco.com.au/CMS/uploads/Manuals/Sand_manual_829006.pdf
The manual has step by step instructions on filling and starting the filter.
The only part it doesnt tell you about is how to empty the old filter media.
To start this:
1. turn off circulation pump
2. Bleed any pressure or vacuum from the system using the bleeder valve, or just rotate the multi-port valve.
3. Open the drain valve at the bottom of the filter if there is one (some dont have one)
4. remove the collar between the multiport valve, and the tank. (this should be 2 phillips head screws)
5.Remove the multi-port valve.
you now have access to the sand.
6. Remove sand by whatever means (either a scoop or a good shop-vac with a thick hose)
be sure to be carefull once you get 2/3 of the way down the inside of the tank. There are LATERALS down there that are most likely brittle from chlorine.
Once sand is removed check and clean the laterals at the bottom of the tank.
Clean and flush the filter body and follow the directions in the manual to fill and start-up the filter.
If this helped, please vote positively for me.
Nov 01, 2010 • Pool & Spa
Top Waterco Pool & Spa Experts
Jay Finke
Jay Finke
 Mikey
Mikey
Are you a Waterco Pool and Spa Expert? Answer questions, earn points and help others
