Home Logo
m
mary Flake Posted on Feb 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What do you do when only half your jets are working in a Mirolin Massage bathtub
pacdave
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 104 Answers
  • Posted on Feb 03, 2019
pacdave
Expert
Level 2:
New Friend:
Cheetah:
Answers
104
Questions
0
Helped
34879
Points
318
Fill the tub until the jets are covered by 2-3 inches of hot water. Add 2 Tablespoons of a low-suds liquid dish wash soap and 1/2 cup of white vinegar. Run the tub with the solution to clean the jets. You can also use bleach instead of vinegar.
What do you do when one half the jets are working in a Mirolin massage tub
Feb 03, 2019 • Home
Do Mirolin water jet tub jets come out for cleaning ?
No they do not here is a simple way to clean the jets and the piping.
Regular Jet Cleaning
To clean the entire whirlpool system and tub exterior, follow this process every month or more frequently if needed. Don't let dirt and grime build up or you'll have more scrubbing to do to get the tub clean.
  1. Fill the tub with hot water, approximately an inch above the highest jet.
  2. Make sure the water temperature reaches at least 140? F (60? C).
  3. Add 1/2 cup of laundry detergent or the amount used to clean 1 load of laundry as recommended by the detergent manufacturer.
  4. Run the jets for 15 minutes.
  5. Drain the tub and refill with clean lukewarm water.
  6. Run the jets for another 15 minutes.
  7. Drain the bathtub.
  8. Dry the tub completely by wiping it down with a clean towel.
Jan 13, 2017 • Jet Home
Mirolin jaccuzzi air tub
If your pump will not shut off then the Air Switch in the motor is most likely the problem with the pump not turning on.
Rod
US Parts Center
Dec 02, 2013 • Home
I have a Mirolin whirpool for 2 years now . Warranty expired just a few months ago. Happened twice this week where after your finished bath there is an automatic blower turn on after 20 minutes where...
Mirolin warranty is horrible. Immediately after install the tub leaked because of a defect in the tub's drain hole. Mirolin won't cover any damages caused. Had to pull our whole ceiling below and replace flooring.
I need new trim parts to change from gold to nickle on a pearl jetted tub model 143391-1 trim rings handle light cover..ect.
go to http://www.uspartscenter.com/shopbybathmfg.aspx you should be able to find the parts for your tub there.
Parts for my pearl corner tub
any plumbing suply house would have it. good luck
1helpful
Broken back massage jet unable to purchase locally
Hi robrezza,
Here's the number the Pearl/maax Plant.
For maintenance, installation or general technical queries about your MAAX products, we encourage you to contact us at: Tel.: 1-888-957-7816 option # 2 Fax: 1-800-201-8308 (418) 387-9086
Have your tub model when you call. They usually are pretty helpful. Sometimes it goes to voice mail for the tech person but they call back after a bit
Please rate this response and Good Luck, Phil
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
