Home Logo
m
mary Flake Posted on Feb 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What do you do when one half the jets are working in a Mirolin massage tub
pacdave
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 104 Answers
  • Posted on Feb 03, 2019
pacdave
Expert
Level 2:
New Friend:
Cheetah:
Answers
104
Questions
0
Helped
34916
Points
318
Fill the tub until the jets are covered by 2-3 inches of hot water. Add 2 Tablespoons of a low-suds liquid dish wash soap and 1/2 cup of white vinegar. Run the tub with the solution to clean the jets. You can also use bleach instead of vinegar.
2 Related Answers
Anonymous
  • 4 Answers
  • Posted on Jun 16, 2009
SOURCE: Two jets stopped working
Most of these jets turn to close. Check if you turn the nozzle. Hope it helps
ka4iup
ka4iup
  • 4062 Answers
  • Posted on Apr 17, 2015
SOURCE: white hydro massage American Standard whirlpool access panel & jets have yellowed in the tub. have used hydrogen peroxide & baking soda. Thank you! * picture tub panel upright On Right side picture
Yellowing is a sign of age, but plastic items can be brightened up a bit. Here are some suggestions:
http://www.howtocleanstuff.net/how-to-whiten-yellowed-plastic/
What do you do when only half your jets are working in a Mirolin Massage bathtub
Feb 03, 2019 • Home
Do Mirolin water jet tub jets come out for cleaning ?
No they do not here is a simple way to clean the jets and the piping.
Regular Jet Cleaning
To clean the entire whirlpool system and tub exterior, follow this process every month or more frequently if needed. Don't let dirt and grime build up or you'll have more scrubbing to do to get the tub clean.
  1. Fill the tub with hot water, approximately an inch above the highest jet.
  2. Make sure the water temperature reaches at least 140? F (60? C).
  3. Add 1/2 cup of laundry detergent or the amount used to clean 1 load of laundry as recommended by the detergent manufacturer.
  4. Run the jets for 15 minutes.
  5. Drain the tub and refill with clean lukewarm water.
  6. Run the jets for another 15 minutes.
  7. Drain the bathtub.
  8. Dry the tub completely by wiping it down with a clean towel.
Jan 13, 2017 • Jet Home
My hot tub has an issue. Only half the display is working, there's no heat and the jets wont turn on. If I trip the curcit, I can get the hot tub jets for 10-30 seconds and that's it. HELp
Almost all hot tubs use 230 volt AC power which comes from the power company in two power wires plus one common common wire. You get common 115 volts between a common and either other wire. "Half way" working could well be an attempt to run on only one of the wires. There is also likely to be a ground fault circuit breaker in the wiring which makes sure current going out to the tub is all returned via the wires and not through someone's legs to ground. If you're comfortable with an AC voltmeter check some voltages but understand that 230 volts is way into the killing range. Two people present and well insulated probes are important.
Apr 15, 2016 • Pool & Spa
Mirolin jaccuzzi tubs
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Jan 28, 2014 • Home
Mirolin jaccuzzi air tub
If your pump will not shut off then the Air Switch in the motor is most likely the problem with the pump not turning on.
Rod
US Parts Center
Dec 02, 2013 • Home
I have a Mirolin whirpool for 2 years now . Warranty expired just a few months ago. Happened twice this week where after your finished bath there is an automatic blower turn on after 20 minutes where...
Mirolin warranty is horrible. Immediately after install the tub leaked because of a defect in the tub's drain hole. Mirolin won't cover any damages caused. Had to pull our whole ceiling below and replace flooring.
1helpful
Stale water odour when jets havent been used on massage type spa
There are several cleaning methods on the internet. I would contact the maker of the tub and see if they have a cleaning agent. I know that Jacuzzi and Aquatic industries have a cleaner that works rather well. I have seen one on the net that uses 2 teaspoons of powder dishwasher soap mixed with bleach. I have not tried this one so don't know how well it works. The ones from the tub companies are not cheap, but if you want something that is going to do the job, spend the money.
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
