Sewing Machines Logo
d
dolores myers Posted on Feb 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need turissa needle plate, 50's machine - Sewing Machines
  • CJ Rock
    CJ Rock Feb 03, 2019
    Well... I use to tell everyone "You can get anything short of a guided missile and fissionable material" on ebay. Looks like I'll need to add "or a Turrissa top plate".
pacdave
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 104 Answers
  • Posted on Feb 03, 2019
pacdave
Expert
Level 2:
New Friend:
Cheetah:
Answers
104
Questions
0
Helped
34877
Points
318
1 Related Answer
Anonymous
  • 46 Answers
  • Posted on Oct 24, 2008
SOURCE: singer 6038 needle issues
That sounds like the needle is not in straight or is bent.
2answers
Pfaff tiptronic 2020
It adjusts the needle plate position front to back.
Where can I find a belt for turissa sewing machine
You can find assorted sewing machine parts from this site.
You did not provide the machine model # ,
http://www.sewingpartsonline.com/lookup.html?keywords=Belt+turissa+
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jamie_580d75bd3bb6d659
1helpful
I am looking for an instruction manual for a Viking Turissa model 2840
gotot http://manuals.husqvarnaviking.com Use the advanced search option and enter your model.
I dont know.if I am doing it.wrong my thread keeps snapping from the needle my ? Is there a certain way to place the bottom bobbin? For a brother xl5130 sewing machine
If your bobbin was in wrong you would get the "crows nest" on the underside of the fabric. There can be several thing that can cause this: your tension is to tight, for normal sewing is usually around 3-5 (check your manual for proper setting). Your needle or throat plate can have a bur on it that is snagging the thread causing it to break. Needles should be thrown away after 50 hours of sewing to avoid problems. The needle can have a slight bend (from over use) and is rubbing on the throat plate causing it to break. and finally...your just not holding your mouth right! :) (...and sometimes this is really true!). Check your tension, pull the thread, change your needle, rub your finger over the throat plate be sure all is baby skin smooth, re thread you machine...deep breath, relax and start again. Hope this helps, Happy sewing.
Line needle plate
try a new needle first, then if the needle doesn't line up with the needle plate, then the machine needs a ajustment or has a timing problem and needs to be checked at a sewing machine shop
Needle hits the plate and bends. What would cause this?
try another needle and see if the needle still bends,, if the needle
still does bends then there could be something wrong with the needle
bar and the machine needs to be checked.
Euro-Pro Shark Sewing machine needle off center, hits needle plate
it sounds like the machine has jumped time & needs to be retimed
at a sewing machine repair shop.
I also suggest you throw away that denim needle, it's very
lightly damaged.
I need to order a part for my euro-pro sewing maching model 50-1262d. this part hold the bobing in place. but I'm not sure of the part name.
Need feed and needle plate for Euro Pro 50-1262D. Don't know what part # to order or where to buy them?
3helpful
2answers
Needle will not sew thread into material
Sounds like the timing is off. Take the bobbin out of the bobbin case and lower the needle into the needle plate. As the needle starts on the upswing, the hook should meet the needle just above the needle eye on most machines. If it isn't meeting at that point then your hook timing will need to be adjusted.
Singer 6038 needle issues
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
